| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#291 |
Sucks as I planned on doing just that and took a break to do it and --- with everything laid out carefully and cutting out the old SK's because I was worried about damaging the solder pads -- I put them in the wrong rail!! Arrrgh. I will try and carefully remove those and swap them for the others I should have replaced. Thanks. I really want to find this out. I was so proud the board looks perfect then...
#292 |
I replaced Q3 and the voltage came right uo.
So if I didn't waste those two spares I might have it working now.Since I have order more I see there's comments about the BL which draw more current. Is there any advantage to these? I wouldn't mix and match but if I'm doing all this anyway I wondered if there's any serious sonic benefit to switching them all out? |
#293 |
Hi phrarod!
You make follow the basic Circuit, not change any thing! The DAC-ASH board , All it is easy to make it!
Group buy DAC-END R (ES9018) full assembled board update 21/5/2013 : https://docs.google.com/spreadsheet/...FE&hl=en#gid=0 |
#294 |
So continue to use the GR version of the 2SK170?
#295 |
#296 |
I will but I still need to order more because I am down one. Is there any benefit of the DL over the BR?
#297 |
I've a R-core transformer stated 50VA, 0-250V(50mA) X 2; 0-7.5V(1A) X 2, is that good matched with the SSHV?
#298 |
I solve the question already, thanks!
#299 |
BL grade 2sk170 had a higher IDSS than the GR grade, the highest one should be 2sk170v
#300 | |
For 6dj8, it is ok! because : 6h30 and 6h6 need 800mA one filament tube, and 20mA 1/2 tube!
| diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? | TonyDasilva | Digital Line Level | 21 | 13th April 2009 05:10 PM |
| Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! | Jambo | Digital Source | 8 | 20th August 2008 09:41 AM |
| Repairing Black Ash veneer | BarakaBloke | Multi-Way | 22 | 2nd March 2008 05:39 PM |
| DPA little bit dac modding (7350 dac, ym3623b receiver) | ash_dac | Digital Source | 16 | 5th December 2007 07:09 PM |
| FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area | owdi | Swap Meet | 5 | 26th July 2007 08:54 PM |
