| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#112 |
[QUOTE=Strosek;2293766]Finally done!! The boards anyway...
![]() It is wonderful! You listen to it?? Can you tell all friends and me please ?? Quanghao
Group buy DAC-END R (ES9018) full assembled board update 8/5/2013 : https://docs.google.com/spreadsheet/...2c&hl=en#gid=0 |
#113 |
No not yet... I just used a single 12 volt transformer to test each power supply one at a time but I'm still waiting on Bud P. for the transformers that will power both boards.
Just wanted to post the completed boards in case it helps others. I'll be upgrading a few caps but for now this is it! So far these have been a very well designed boards! Thanks Quanghao |
#114 | |
#115 |
Hi Quanghao,
Need help to trouble shoot the B+ for IV board. I using 6H30 tube, transformer 200Vac. The HV regulator can set the voltage 230V without tubes in. After plug in the tubes and power on, the voltage drop to 137V when tubes heated up and cannot adjust up higher. AC in measures 216V, dc is 275V before R1 22Ohm and 248V after. The DAC-End board is fixed and all +/- 5v supply is working. |
#116 | |
#117 |
Yea, I just check and R1 I made a mistake was 33 ohm,too high not 22R. Voltage drop at R22,21,37,38 = 220R <- (220 is ok?) is 2.6-2.85V.
#118 | |
R1 set current for SSHV Supply =22 Ohm, Ia ( I total ~95-100 mA) So Iv need total= 80mA, 1/2 Triode 6h30 need 18-20mA.( the sound is the most ) And Voltage at Anode =90-100V, So voltage at R 22, 21,37,38 =3.8-4V , and R =200-220 Ohm, it is ok! Thanks You see it???
#119 |
[QUOTE=BudP;2292895]Hi everyone,
Very professional! You can keep this price and additional output is not? namely: 8 or 10 outputs 9V/500mA. Thank you! I'd love to have one like that! Quanghao
#120 | |
| diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? | TonyDasilva | Digital Line Level | 21 | 13th April 2009 05:10 PM |
| Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! | Jambo | Digital Source | 8 | 20th August 2008 09:41 AM |
| Repairing Black Ash veneer | BarakaBloke | Multi-Way | 22 | 2nd March 2008 05:39 PM |
| DPA little bit dac modding (7350 dac, ym3623b receiver) | ash_dac | Digital Source | 16 | 5th December 2007 07:09 PM |
| FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area | owdi | Swap Meet | 5 | 26th July 2007 08:54 PM |
| Page generated in 0.18723 seconds (100.00% PHP - 0% MySQL) with 10 queries |
