Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 28th December 2010, 09:23 AM   #411
Yomanze is offline Yomanze  United Kingdom
Hi Quanghao or anyone else with a working DAC, would you recommend using the A, B or C variants of bc550 / bc560? On an aside have got all the other parts ordered, so am looking forward to building soon!
Old 30th December 2010, 12:30 PM   #412
quanghao is offline quanghao  Viet Nam
DAC-ASH (dac-end 2 up date) Send a message via Yahoo to quanghao DAC-ASH (dac-end 2 up date)
I not see it! can you tel me again??
Thanks!
Quanghao
Old 30th December 2010, 01:18 PM   #413
Thanks!
Quanghao
Hi Quanghao, don't worry about it. Found this post & noticed that people were ordering 512-BC550 and 512-BC560 (Mouser.com codes), so put an order in yesterday.
Old 30th December 2010, 03:47 PM   #414
Yomanze: Have been getting the parts together for this DAC & having looked at the layout I think it is worth hardwiring the CS8412/4 loopfilter caps in a 'v' shape between pins 20 and 21. Anyone tried this?
Quanghao: You want say the layout have problem???
Hi Quanghao,
Only just saw your reply. Extremely short lead/trace lengths are very important here. Please see the CS8416 datasheet:
"For minimum PLL jitter, return the ground end of the filter network directly to AGND." and:
"The type of capacitors used for the PLL filter can have a significant effect on receiver performance. Large
or exotic film capacitors are not necessary as their leads and the required longer circuit board traces add
undesirable inductance to the circuit."
http://www.cirrus.com/cn/pubs/proDat.../CS8416_F3.pdf
Although the loop filter for the CS8416 is different there's loads of great info from page 53 onwards including layout examples.
Best regards,
Neil
Old 30th December 2010, 11:27 PM   #415
Hi!
yes! that is The boo for Salas Low shunt V1.0
Not use Cs8416 change for Cs8414!
Old 31st December 2010, 09:15 AM   #416
Hi!
Hi Quanghao, am actually using CS8412-CP with 330r / 0.47uf loop filter. :P
Old 31st December 2010, 09:19 AM   #417
No!
Only Cs8414, you can not use Cs8412!
If you like Cs8412 you have to change cricuit folow Adionot DAC!
Old 1st January 2011, 08:02 AM   #418
No!
Hi Quanghao, have looked at both circuits & CS8412 does appear to be pin-compatible, so it should work. Only differences I could see are use of an LED + resistor (pin 28) in the DAC ASH circuit (which I'm not using) and use of cc/f0 (pin 23) for input switching on the Audio Note DAC. Unless I am missing something?!
Old 3rd January 2011, 09:09 AM   #419
please se cricuit of Audio note!
Old 6th January 2011, 09:48 PM   #420
ksnider1 is offline ksnider1  United States
Default DAC-ASH PCB (dac-end 2 up to date)
Hi Quanghao, do you have DAC-ASH PCB in stock ? I tried to order it via your website but something went wrong in last part of order. Can I oder it from you here. Let me know and will send you payment.
DAC-ASH (dac-end 2 up date)Hide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
Repairing Black Ash veneer BarakaBloke Multi-Way 22 2nd March 2008 05:39 PM
DPA little bit dac modding (7350 dac, ym3623b receiver) ash_dac Digital Source 16 5th December 2007 07:09 PM
FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area owdi Swap Meet 5 26th July 2007 08:54 PM
