Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 21st December 2010, 10:03 AM   #391
phrarod is offline phrarod  United States
Just for grins. Here's the Audio Note Dac board schematic (kit board not production board)
Old 21st December 2010, 10:38 AM   #392
la1209 is offline la1209  Hong Kong
Maybe some area or pinout of the 74HC04 shorted to GND. You can check the pin without the chip, and check it point to point to see is there any point being shorted to ground.
Old 21st December 2010, 11:05 AM   #393
Jogi is offline Jogi  Germany
it seems that the chips are not the reason, because you changed them all with no result.
Are you sure that all of the chips receive the 5V?
You should measure the voltage at the capacitors close to the chips.
If it is wrong there, the fault must be BEFORE the actual dac chips, either the salas shunt or the tl431 circuit.
I had a similar bug, because I soldered some wrong resistors (belonging to the tl431 circuit), so the chips had the wrong voltage, although the salas shunt was working properly.
When the tl431 has not enough voltage, it distorts btw.
I blew one ad1865, fortunately I had another one.
good luck, it is worth the trouble soundwise...
cheers,
Juergen
Old 21st December 2010, 04:35 PM   #394
I did a continuity check to ground on all the pins of 74H last night and there was no short there.
Just now I removed the 8414 then tested the 74H. Same result
Then I removed the 1865 - Same result
Then I swapped in and out the CS and 1865 and no result.
Does this chip have a closer relationship to the CS8414 or the AD1865?
I get fine voltage on the V-in of this chip just not on all the v-out
Old 21st December 2010, 06:58 PM   #395
At the suggestion of a tech I pulled the 74H chip and tried it and I have the same distortion.
Old 21st December 2010, 10:10 PM   #396
Some progress.
I built a small rig and put one of the 74H chips in it and fed the chip voltage. In the rig all the pins that should have voltage do. IE they all have the proper 5V.
If I power the chip only in the board I do not get those voltages. This proves the chips are ok.
Old 21st December 2010, 11:31 PM   #397
I completely give up. I'm happy for others who were able to make this board work but I cannot.
I looked at every single trace and touched up every single solder joint. There is no change at all when the chips are in the board. None.
I suspect a problem with the PCB but I have no clue. Its no frustrating and defeating.
Old 22nd December 2010, 12:35 AM   #398
quanghao is offline quanghao  Viet Nam
DAC-ASH (dac-end 2 up date) Send a message via Yahoo to quanghao DAC-ASH (dac-end 2 up date)
I not Know, what i can help you now??
only say, please sent to me, i can fix it to you!
I no known where it is wrong in the PCB??
there are many member was successful with PCB!
Old 22nd December 2010, 01:14 AM   #399
Maybe I got the bad one of the bunch. I'll hope someone in the U.S. can help but if they can't I'll just put the old board back in and maybe send it to you.
Old 22nd December 2010, 10:27 AM   #400
lucylu is offline lucylu  England
Hello Well i have sorted the heater volts out 6.3 and hv +300.
On the other board the rails are + 5v -5V that was the easy part .
All the 5v points around the chips are ok except pin 12 on 1865 it reads 2.5 v traced it back to pin 12 on 8414 it reads the same ?
i noticed that the led l19 did not come on .
am taking apart to check for bad joints .
cheers john
DAC-ASH (dac-end 2 up date)Hide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 06:10 PM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 10:41 AM
Repairing Black Ash veneer BarakaBloke Multi-Way 22 2nd March 2008 06:39 PM
DPA little bit dac modding (7350 dac, ym3623b receiver) ash_dac Digital Source 16 5th December 2007 08:09 PM
FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area owdi Swap Meet 5 26th July 2007 09:54 PM
