Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 17th August 2010, 10:36 PM   #21
parodielin is offline parodielin  United States
Originally Posted by quanghao View Post
I can sell all resistors for this DAC!
Would you care to post a price on all resistors? I can move on to other parts.
Old 17th August 2010, 10:37 PM   #22
Strosek,
Would you mind sharing your BOM with links to suggested components (if it's not too much trouble)?
Originally Posted by Strosek View Post
Quanghao, the circuit for SSHV posted above lists for D5 & D6 - 1N4142A but the BOM (on page 179 of the original thread) says 1n4172?
I suspect the part we want here is 1N4742 or 1N4742A a 1W 12V Zener Diode....
Is this correct and if it is could you please make the corrections to the circuit so others don't have a problem.
Thanks!
Old 18th August 2010, 01:16 AM   #23
Strosek is offline Strosek  Canada
Originally Posted by parodielin View Post
Strosek,
If I had one I'd be happy to share It but all I did was use Quanghao's BOM and I just held off on ordering parts that I wasn't sure about ie. the diodes I just posted about.
I sourced most of the parts from Mouser, Digikey and just a few things off ebay.
I'm 95% done... I held off on the diodes and power supplies which I'm hoping to get from Bud P if he ever responds to my PM's.
If you need specific assistance with a certain parts please PM directly and I'll see what I can do as I do have many extras.
Thanks!
Old 18th August 2010, 02:46 AM   #24
quanghao is offline quanghao  Viet Nam
DAC-ASH (dac-end 2 up date) Send a message via Yahoo to quanghao DAC-ASH (dac-end 2 up date)
measured parameters of I / V stage DAC-ASH
Old 18th August 2010, 03:32 AM   #25
Hi! you see it:
CCF50
Vishay Dale
Metal Film Resistors, Industrial, 1 % and 5 %
http://www.vishay.com/docs/31014/ccf50.pdf
For DAC-ASH
470R x 1
75 x 1
560 x 1
33 R x 6
10 R x 6
47R x 6
100 R x 6
220R x 6
Total: 10$
Old 18th August 2010, 03:50 AM   #26
Thanks for the link and price!
One quick question, in the BOM, there are 1/4W, 2W right next to resistors. I assume these mean power rating of resistors. The spec of CCF50 says it's 0.33W so it can handle 1/4W OK but how about "2W" on the 33 ohm resistor?
Hi! you see it:
CCF50
Vishay Dale
For DAC-ASH
470R x 1
75 x 1
560 x 1
33 R x 6
10 R x 6
47R x 6
100 R x 6
220R x 6
Total: 10$
Old 18th August 2010, 03:56 AM   #27
Yes! 33R use
VISHAY / DALE RN65D SERIE : 75R// 49R
Old 18th August 2010, 06:25 AM   #28
hotzman is offline hotzman  Romania
5. Resistor
Resistor 1/2W 3.3 Ohm x 1 R7
47 Ohm x 2 R9,R10
200-220 Ohm x 1 R13,R2,R6
6.8K Ohm x 1 R14
On PCB R13 6K8!
R14 200-220Ohm!
which version is correct? (scheme corresponds PCB)
Thank you!
Old 18th August 2010, 06:39 AM   #29
Originally Posted by hotzman View Post
5. Resistor
47 Ohm x 2 R9,R10
6.8K Ohm x 1 R14
On PCB R13 6K8! = 6.8K
R14 200-220Ohm! = 200 or 220R
Thank you!
No correct!
Old 19th August 2010, 12:59 AM   #30
No correct!
Please explain.... Which is correct? I don't understand?
THX
DAC-ASH (dac-end 2 up date)Hide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
Repairing Black Ash veneer BarakaBloke Multi-Way 22 2nd March 2008 05:39 PM
DPA little bit dac modding (7350 dac, ym3623b receiver) ash_dac Digital Source 16 5th December 2007 07:09 PM
FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area owdi Swap Meet 5 26th July 2007 08:54 PM
