Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 16th August 2010, 06:49 PM   #11
klaju1955 is offline klaju1955  Brazil
Originally Posted by parodielin View Post
Eaagerly waiting. Any plan for getting the chips? I saw a few group buy on the AD1865. Are we in a stage that reputable eBay sellers are there?
I need already the AD1865N-K, digikey only sell 15, therefor itīs good to make a group buy, perhaps together with other chips.
Many people just asked if itīspossible to buy at Ebay, and it seems one seller is good, but nobody stays without doubt and the most bought in group buy on Digikey, the only official source I know.
Klaus
Old 16th August 2010, 07:36 PM   #12
phrarod is offline phrarod  United States
About to order parts. Updated BOM please.
Old 17th August 2010, 01:51 AM   #13
quanghao is offline quanghao  Viet Nam
DAC-ASH (dac-end 2 up date) Send a message via Yahoo to quanghao DAC-ASH (dac-end 2 up date)
This is circuit SSHV for IV Stage
Old 17th August 2010, 03:43 AM   #14
Default The bom Of DAC-ASH
Parts List DAC-ASH
Resistor Vishay/Dale CCF50 1/4W:
470 Ohm x 1 R39
75 Ohm x 1 R41
680Ohm x 1 R40
Resistor Caddoc MK132:
200 Ohm x 2 R37,R38
Capacitor Vishay/BC
0.1uF/12V x 6 C26,C28,C30,C32,C34,C36
0.01uF x 2 C38,C39 (at digital input), C40,C41
68nF/63V x 1 C37
Sanyo os-con - electrolytic capacitors:
47uF/10-16V x 6 C24,C27,C29,C31,C33,C35
Chip
CS8414 x 1 U3 Cirrus Logic Inc
74HC04 x 1 U2 Toshiba
AD1865 NK, NJ, N x 1 U1 Analog Devices
Socket: 28 pin, 24pin, 8pin
Inductor: 120uH x x 2 L1, L2
Led: GREEN LED x 1
SPDIF: Transformer x 1 T2 Newava Technology S22083 or LL1572
Salas Shunt on The DAC
JFet Toshiba
2SK170 x 18 Q2,Q3,Q5,Q8,Q9,Q11,Q14,Q15,Q17 Q20,Q21,Q23,Q26,Q27,Q29,Q32,Q33,Q35 Transistor
Transistor Fairchild Semiconductor
BC560 x 1 Q10
BC550 x 5 Q4,Q16,Q22,Q28,Q34
Mosfet
On Semiconductor International Rectifier (IR)
IRF540 x 2 Q7,Q12
IRF9540 x 10 Q1,Q13,Q19,Q25,Q31,Q6,Q18,Q24,Q30,Q36
Electrolytic Capacitors / Rubycon ZLH or Panasonic FC
220uf/16V x 6 C3,C7,C11,C15,C19,C23
2200uF-4700uF/25V x 6 C1,C5,C10,C13,C17,C21
Capacitor Illinois Cap & Wima, etc...
0.1uF/25V x 12 C2,C,C6,C10,C14,C18,C22,,C4,C8,C12,C16,C20,C24
Resistor Vishay / Dale CCF50 1/4W
10 Ohm x 6 R4,R11,R16,R22,R28,R34,
47 Ohm x 6 R5,R11,R17,R23,R29,R35
100 Ohm x 6 R3,RR9,R15,R21,R27,R33
220 Ohm x 12 R2,R8,R14,R20,R26,R32,R6,R12,R18,R24,R30,R36
Resistor Vishay / Dale CCF50 2W
33 Ohm / 2W x 6 R1,R7,R13,R19,R25,R31
Led Green Led x 18 L1-L18
Diode 1N5819 Schottky Barrier Rectifier
40V x 24 D1-D24 . http://www.oup.com/us/pdf/microcircu...n5817-fair.pdf
Trimmer Fairchild Semiconductor
VR 1K Ohm x 6 VR1-VR6
Tranformer
9-12 V/100-200mA x 6
Old 17th August 2010, 04:04 AM   #15
Default The Bom IV stage for DAC-ASH
IV stage for DAC-END
Composite-Triode
1.Resistor
Resistor 2W
R1,R31 = 22R/2W
R16 - R20A = 18K/2W
R32 - R36A = 18K/2W
Resistor 1/4W
R22,21,37,38 = 200R
R23,24,39,40 = 470K
R25,26,27,28 = 2K
R41,42,43,44 = 2K
R29,30,45,46 =220K
R52 = 10R
Resistor RELAY
ALL 1/4W
R47 = 220K
R48= 1K
R49 = 5.6K
R50,51 = 4.7K
2. Caps
C16, 22: 47uF/450V
C19, 21 ,24, 26 = 220uF/16V
C19,20,25,26 = 0.1uF
Caps -output:
C17, 23: 0.47 - 1uF/450V (Jensen, Audicap, M-Cap…)
Caps RELAY
C28: 47 - 220uF/12V
3. DS2Y RELAYS 5v X 1
4. Transitor
Q1: BC337
5. IC: LM311
6. Diot: D19, d20 = 1N4007 or better
7.Tube: V1, V2 = 6H30Pi, 6H6Pi, or 6dj8 x 2
8 .
Tube Socket 9 PIN X 2
9. PCB I/v stage X 1
Note:
1. All resistor 1/4W or 1W
2. R1, R31: 22R/2W. R16 - R20A use 2W. R32 - R36A use 2W
2. The delay time : 0.45 minutes
Use Tube:
1.Tube 6H6PI:
+B = 270V. R22, R21, R37, R38 = 400R - 470R.
2.Tube 6H30PI:
+B = 230V. R22, R21, R37, R38 = 200 - 220R.
3.Tube 6DJ8 or 6H23:
+B = 200V. R22, R21, R37, R38 = 280R - 300R.
* R16 - R20A = 47K/2W .
* R32 - R36A = 47K/2W.
Parts List Salas Shunt for iV stage
1. JFet:
2SK170 x 1 Q4
2. Transistor
2N2906 x 1 Q5
MJE 350 x 1 Q2
3. MosFfet
IRF9610 x 1 Q1
IRF840 x 1 Q3,Q15
3. IC
LT1084, 85 x 1 U1
4. Capacitor
220uf/450V x 2 C4,C5
1uf/450V x 2 C2,C3
100uF/25V x 1 C1
4700uF/16V x 2 C10,C11
470uF/16V x 2 C12,C14
47uF/16V x 1 C13
0.1uf/16V x 5
5. Resistor
Resistor 1/2W 3.3 Ohm x 1 R7
47 Ohm x 2 R9,R10
200-220 Ohm x 1 R13,R2,R6
6.8K Ohm x 1 R14
Resistor 2W
33 Ohm x 1 R1 for Tube 6H6Pi and 6H30Pi,
47 Ohm x 1 for Tube 6Dj8
5.6 K x 1 R5
120 K x 1 R4
100 Ohm x 2 R15,R16
Resistor 5W
56K x 1 R3
6. Trimmer
2-5 K Ohm x 1 VR2
500-1K x 1 VR1
7. Led Green Led 3 D2,D3,D4
8. Diode
Diode 4A x 4 D13,D14,D15,D16
Diode 1N4007 x 2 D17,D18
Diode 1n4007 or better x 4 D9,D10,D11,D12
http://www.datasheetcatalog.org/data...en/mXqxxyz.pdf
Diode Zenner
1n4742 or zener diode 6- 12V
TRANFORMER
SALAS SHUNT 1 0-200-250V/100mA
Filament x 1 0-8V or 0-9V/2A
Heatsink
10W x 2 Q1,Q3
5-10W x 1 U1
Jump
3 x 2
Old 17th August 2010, 04:25 AM   #16
parodielin is offline parodielin  United States
Started from the first item: 470 ohm and 680 ohm resistors are "non-stock" in Mouser, minimum order is 5000. Couldn't find them in DigiKey. Did I miss anything?
I am new.
Originally Posted by quanghao View Post
Parts List DAC-ASH
470 Ohm x 1 R39
75 Ohm x 1 R41
680Ohm x 1 R40
Old 17th August 2010, 04:34 AM   #17
I am new.
I can sell all resistors for this DAC!
Old 17th August 2010, 01:15 PM   #18
Strosek is offline Strosek  Canada
Quanghao, the circuit for SSHV posted above lists for D5 & D6 - 1N4142A but the BOM (on page 179 of the original thread) says 1n4172?
I suspect the part we want here is 1N4742 or 1N4742A a 1W 12V Zener Diode....
Is this correct and if it is could you please make the corrections to the circuit so others don't have a problem.
Thanks!
Old 17th August 2010, 01:37 PM   #19
Strosek - does the DAC-ASH look correct?
Old 17th August 2010, 01:37 PM   #20
[QUOTE=Strosek;2275362]Quanghao, the circuit for SSHV posted above lists for D5 & D6 - 1N4142A but the BOM (on page 179 of the original thread) says 1n4172?
Hi! Im sorry
that is I m wrong, 1n4142 is correct!
1n4742 and 1n4742 is one, this is zenner diode 12V
My be not need this Diode, if you can not fine it , you can change Zenner diode from 6.8V to 15V, 1/2W.
SSHV many time not need this diode, but It is still very excellent!
DAC-ASH (dac-end 2 up date)Hide this!Advertise here!
diyclub.biz DAC-38, DAC-60, DAC-68. Anybody heard? TonyDasilva Digital Line Level 21 13th April 2009 05:10 PM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
Repairing Black Ash veneer BarakaBloke Multi-Way 22 2nd March 2008 05:39 PM
DPA little bit dac modding (7350 dac, ym3623b receiver) ash_dac Digital Source 16 5th December 2007 07:09 PM
FS: Unfinished ash baffles from my OB project - $25 - Seattle, WA area owdi Swap Meet 5 26th July 2007 08:54 PM
