Pre-dac - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 26th June 2010, 05:13 AM   #1
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Default Pre-dac
Hi all!
After successfully DAC-END, Andrea and I designed a PRE-DAC, dac output, or used as a separate Pre, use tube 6h30, 6h6 ỏ 6DJ8 with the output impedance of around 1.2 K.
Especially I used Salas shunt for HV (SSHV), a PCB would be a perfect PRE including the tube and the source
Perfect for the support of the DAC output without using a rear Pre
You can se cricut and some image!
Old 26th June 2010, 05:15 AM   #2
and more
Old 4th February 2011, 04:31 AM   #3
Strosek is offline Strosek  Canada
R15 & R31 should it be 22R or 220R??
Thanks!
Old 4th February 2011, 10:42 PM   #4
Default Pre DAC
Hi Quanghao,
Is this PCB going to be available to buy and if so how much please?
John Caswell
Need help: tube DAC and Phono pre-amp jazzmanzack Tubes / Valves 6 7th November 2010 06:56 AM
need a PS for a pre, DAC, and headphone amp fishski13 Power Supplies 6 12th February 2009 07:59 PM
Pre-DAC switching capability? Commited Digital Source 5 9th January 2006 06:29 PM
Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier GIPIONE Solid State 8 18th December 2005 10:09 PM
Simple and Low noise Pre-regulators for DAC machinow Digital Source 2 10th September 2004 02:04 PM
Copyright 1999-2017 diyAudio
