Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 8th October 2012, 05:58 PM   #31
wendell c is offline wendell c  United States
hi quanghao,
Using the Salas LV shunt I bought from you also, I will be using with 4 x 34 Vac / 20VA
for the Roender FC-100 amp the Rudi is offering.
What is the best component to use for this application? Shunts will be providing power to front-end of amp.
Old 10th October 2012, 07:52 PM   #32
quanghao is offline quanghao  Viet Nam
Salas low voltage shunt regulator (V 1.0 ) for DAC and more Send a message via Yahoo to quanghao Salas low voltage shunt regulator (V 1.0 ) for DAC and more
Originally Posted by wendell c View Post
hi quanghao,
Hi!
yes, can use whit 34VAC, but need change BC550 and bc560 by othe transistor hight voltage.
How many MA do you need for system?
No use for it, because need Heatsinks very bic
Old 10th October 2012, 09:10 PM   #33
the current is 21.5mA @ +/-38-39 VDC per frontend-rail.
Old 11th October 2012, 09:05 AM   #34
21mA, it is ok, and it is ok vol,
you can use it
thanks
Salas low voltage shunt regulator (V 1.0 ) for DAC and moreHide this!Advertise here!
OLD THREAD Salas low voltage shunt regulator (V 1.0)for DAC quanghao Quanghao Audio Design 15 16th July 2010 05:05 AM
