Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 28th September 2010, 04:25 AM   #21
quanghao is offline quanghao  Viet Nam
Salas low voltage shunt regulator (V 1.0 ) for DAC and more Send a message via Yahoo to quanghao Salas low voltage shunt regulator (V 1.0 ) for DAC and more
Originally Posted by Yomanze View Post
Hey Quanghao,
How about producing PCBs with one shunt per board, positive or negative? Anyone else think this is a good idea? Would buy 4x for an I/V stage.
Neil
I have to do it, there are two Power supply + And one power supply -, you butcher into 3 separate PCB.
I calculate the group permission to buy for you! If I'm going to do now!
Thank you!
Old 28th September 2010, 05:44 AM   #22
This layout
Old 20th December 2010, 08:06 AM   #23
mravinsky is offline mravinsky  Europe
Is there any possibility to buy a pair of these boards now?
Old 29th August 2011, 08:26 PM   #24
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
What is the dropout voltage for Salas LV regulator?
Regards Åke
Old 30th August 2011, 08:13 AM   #25
R.I.P.
the CCS requires ~5V to operate correctly.
The recommended minimum supply voltage is: regulated output voltage +7V
regards Andrew T.
Old 3rd October 2012, 03:58 AM   #26
albertli is offline albertli  Canada
albertli's Avatar
Default Old PCB
Quanghao,
I have a complete LV shunt pcb from you sometime ago, but can't find the schematic for it even I search your forum and or your shop. It says V 1.0 on the broad but there is no Leds marked on the broad. Would you please take a look and advise where I could find the schematic so I could go on with my project - The Lightspeed attenuator.
Albert
BTW you can email me if you want.
Old 3rd October 2012, 04:37 AM   #27
Hi albertli!
please the post 3!
thanks
Old 3rd October 2012, 05:00 AM   #28
albertli's Avatar
Sorry I've found a big different with the schematic you showed. Below are what was printed on my broad for 1.5 - 5v.
Q1 IRF9520, Q2 BC560, Q3 K170, Q4 BC550, Q5 K170, Q6 D45H8. You can also check with the picture attached.
Old 3rd October 2012, 05:12 AM   #29
hi!
IRF9520, use IRF9540
D45h8 can use IRF9540
thanks
Old 3rd October 2012, 05:19 AM   #30
albertli's Avatar
Thanks for the fast reply.
It doesn't need Leds for reference ??
Salas low voltage shunt regulator (V 1.0 ) for DAC and moreHide this!Advertise here!
OLD THREAD Salas low voltage shunt regulator (V 1.0)for DAC quanghao Quanghao Audio Design 15 16th July 2010 05:05 AM
