Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 23rd September 2010, 03:38 PM   #11
quanghao is offline quanghao  Viet Nam
Salas low voltage shunt regulator (V 1.0 ) for DAC and more Send a message via Yahoo to quanghao Salas low voltage shunt regulator (V 1.0 ) for DAC and more
Originally Posted by kevinahcc20 View Post
Quanghao,
You mention above that the individual sections of the PCB can be separated. The board design looks pretty tight at the junctions...perhaps you can add a dashed line to indicate the cut line for separating? Do you have a BOM list?
Hi! thanks your advance!
Now im testing with Salas CCS v1.2 with Salas shunt V1.
When it have good the layout out, i can open it again!
Thanks!
Old 23rd September 2010, 03:47 PM   #12
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I don't know what you are mixing but If you will issue a full V1.2 to the general plug n' play public it will be a support nightmare, brace yourself.
Old 23rd September 2010, 03:56 PM   #13
No! i test about The V1.2 CCs with Bc560 and 2n5459, 2sk170
An shunt of V1.0 ( i like it)
If CCs V1.2 it work good with V1.0 Shunt, i can make it for diy!
What do you think it?
Thanks for advace!
Old 23rd September 2010, 04:00 PM   #14
Hi ! Salas!
Now V1.0. it is very good at 3.3V, use MJE350 or Bd140!
Old 23rd September 2010, 04:04 PM   #15
Salas's Avatar
Thanks for advace!
Well, its a faster CCS, positive to have, should be no problem if it will work in your layout as a hybrid with a proven V1 shunt part. Make sure its absolutely stable on scope and for enough practical real life tests. VR1 1K will never take it to tens of Volt out. Also your 5459s will be dead at 40V you aspire. Designate a 5k trimmer and 28V max in 22V max out spec.
Old 23rd September 2010, 04:16 PM   #16
Salas's Avatar
Hi ! Salas!
I know, I have communicated such below 5V BJT solutions for TT DC motors and #26 filaments ages ago. MJE is 500mA max though, you better spec moderate loads and settings for such, before your customers will rev em up thinking they are like the Mosfets stuff.
Old 23rd September 2010, 04:28 PM   #17
Salas!
you go to your topic: I post one image!
The simplistic Salas low voltage shunt regulator
Old 25th September 2010, 08:34 AM   #18
regal is offline regal  United States
Quanghoa, Are you planning on offering negative shunt reg boards?
Old 25th September 2010, 01:46 PM   #19
Hi! Regal!
Yes! i will make it with GR !
Old 27th September 2010, 07:21 PM   #20
Yomanze is offline Yomanze  United Kingdom
Hey Quanghao,
How about producing PCBs with one shunt per board, positive or negative? Anyone else think this is a good idea? Would buy 4x for an I/V stage.
Neil
Salas low voltage shunt regulator (V 1.0 ) for DAC and moreHide this!Advertise here!
OLD THREAD Salas low voltage shunt regulator (V 1.0)for DAC quanghao Quanghao Audio Design 15 16th July 2010 05:05 AM
