| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
I have just completed DAC End assembly. I’ve used LT1085 for the filament regulator, R8,R9 2.2R R11 560R. The supply I/V is 0- 250V and 0-9 V 3A. I was able to adjust for 6.3V and measured 268-274V for HV. I have also applied the LED mod. I did not apply yet SPDIF trafo and I use as SBDIF interface M2TECH HIFACE USB. Tubes are GE 7044. The sound is as described by adamus, sweet yet very detailed although it is not much forgiving for bad recordings.
However I experience an initial relay chattering for two or three seconds before it stabilizes and then the DAC runs with no problems. Also I can hear low frequency hum that becomes noticeable when the music is paused starting from pot position 11 o’clock on my MF X-CANv8 HeadAmp. I have no scope, only a multimeter. Any hints for the relay chattering and mostly for the hum? |
#2 |
Nice !
congratulations! noise can be filtered out by HV yet.
Group buy DAC-END R (ES9018) full assembled board update 8/5/2013 : https://docs.google.com/spreadsheet/...2c&hl=en#gid=0 |
#3 |
some image my Firend is making DAC-end, and up dat
#4 |
I’ve changed R8, R9 to 1.2R and no more relay chattering. Also while inspecting the I/V I found excess of solder on HV power connection that was very near the ground, removed it and no more hum. Now is dead quiet. This is a really great DAC.
Thanks Quanghao, Andrea and Sallas. |
#5 |
It is very good to see you back here in the forums.
For a little time it seemed that the DAC END thread was dead and gone. It was very suddenly cut off. Jeff Davison |
#6 | |
Well I can work, Sorry you had to wait long Please Update the list yourselves when you type here: Hi quanghao, I've paid for my set through paypal. Thanks. 1. pathetic (1 set - PAID) 2. cchean ( 2 sets ) 3. Lucylu (1 set) 4. Ulyses31 (1 set) 5. damohpi (1 set dac end 2 pcb) 6. mikvous (4 sets) 7. gipione ( 1 set) 8. flocchini (1 6h6P if done, 1 Salas HV) 9. belkoff (full set dac end 2 + 1 6h6P if done, 1 Salas HV) + schematic for each PCB 10. klaju1955 (1 set) 11. ben-jam-in (1 set) 12. morpheous 13. hotzman (2 x full set new dac end 2 pcb) 14. le´flu (one complete set of new DAC-pcb) 15. klie (1 set) 16. Yomanze (1 DAC PCB only) 17. Ferrari (1 full set + 1 extra I/V stage PCB) 18. Sugden (1 set) 19. rolotube (1 set - PAID)
#7 |
2. cchean ( 2 sets ) 3. Lucylu (1 set) 4. Ulyses31 (1 set) 5. damohpi (1 set dac end 2 pcb) 6. mikvous (4 sets) 7. gipione ( 1 set) 8. flocchini (1 6h6P if done, 1 Salas HV) 9. belkoff (full set dac end 2 + 1 6h6P if done, 1 Salas HV) + schematic for each PCB 10. klaju1955 (1 set) 11. ben-jam-in (1 set) 12. morpheous 13. hotzman (2 x full set new dac end 2 pcb) 14. le´flu (one complete set of new DAC-pcb - PAID) 15. klie (1 set) 16. Yomanze (1 DAC PCB only) 17. Ferrari (1 full set + 1 extra I/V stage PCB) 18. Sugden (1 set) 19. rolotube (1 set - PAID) |
#8 |
2. cchean ( 2 sets ) 3. Lucylu (1 set) 4. Ulyses31 (1 set) 5. damohpi (1 set dac end 2 pcb) 6. mikvous (4 sets) 7. gipione ( 1 set) 8. flocchini (1 6h6P if done, 1 Salas HV) 9. belkoff (full set dac end 2 + 1 6h6P if done, 1 Salas HV) + schematic for each PCB 10. klaju1955 (1 set) 11. ben-jam-in (1 set) 12. morpheous 13. hotzman (2 x full set new dac end 2 pcb) 14. le´flu (one complete set of new DAC-pcb - PAID) 15. klie (1 set) 16. Yomanze (1 DAC PCB only) 17. Ferrari (1 full set + 1 extra I/V stage PCB - PAID) 18. Sugden (1 set) 19. rolotube (1 set - PAID) |
#9 |
and some image my friend make DAC-END updat
#10 |
PCB DAC-End (DAC+Salas shunt for DAC)
Material: FR4 – 1.6mm Layers: 2 Board size: 118 x 230 mm Surface finish: Immersion Gold Soldermask: Both sides – RED Silkscreen: Legend on top
| Cleo: End to End 24bit 192khz USB DAC with tube output | bcherry | DIY HiFi Supply | 7 | 3rd July 2010 11:15 PM |
| Low end support for single driver monitors | strider75 | Multi-Way | 97 | 30th September 2009 03:02 PM |
| Looking for a Scott Nixon DAC (USB support required) | gmathur | Swap Meet | 1 | 24th February 2009 11:37 PM |
| HELP! How to run iPod to DAC | MTO audio | Solid State | 5 | 13th February 2008 10:44 AM |
| Ok to run high-end headphones with amp output? | The Paulinator | Solid State | 15 | 17th April 2004 07:08 PM |
