Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 29th November 2010, 01:08 PM   #451
quanghao is offline quanghao  Viet Nam
OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas) Send a message via Yahoo to quanghao OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas)
Originally Posted by gmant123 View Post
Hi:
Any kits left?
Please Letme know.
Do you like my kit??
Old 29th November 2010, 10:28 PM   #452
gmant123 is offline gmant123  Argentina
gmant123's Avatar
Yes, it is available for purchase?
Old 29th November 2010, 11:16 PM   #453
hi! you can choice it in my web:
http://quanghao.com/product.php?id_product=57
Old 18th January 2011, 07:00 PM   #454
markenvy is offline markenvy  Italy
On you website I can't purchase the sshv pcbs because shipping is not availaible for my country, Italy. How can I do?
Old 19th January 2011, 10:26 AM   #455
noizas is offline noizas  Lithuania
Same problem: Lithuania is also outside the possible shipping destinations.
Old 19th April 2012, 05:47 PM   #456
nikhilji is offline nikhilji  United States
Hi Quanghao,
Sorry for resurrecting this old thread, but I finally got around completing the SSHV1 for the D3A phono (i was using the Janus shunt before to power the D3A phono board). I need some help with the bring up.
I'm not getting over 165V on B+ when I power the SSHV with a variac.. When I turn the variac slowly, it voltage continues to increase until AC voltage is at 90V (Vin is about 220V), but does not continue to rise after that. The IRF9610 becomes very hot after that point (even with load resistor). When I vary the trimmer pot, I get the voltage variation on Vout, but I get only a max of 165V.
FYI, I'm using Red LEDs instead of the green ones - is that going to matter in this case ?
I also need some general tips for bringing up this regulator board.
Thanks,
nikhil
Old 20th April 2012, 06:50 AM   #457
Problem solved - it was wrong value of resistor in R4
Originally Posted by nikhilji View Post
Hi Quanghao,
Thanks,
nikhil
Old 23rd April 2012, 06:40 AM   #458
Hi nikhilji
yes use green led, and change Irf 9610 ,for CCS
thanks
Old 4th May 2012, 10:13 PM   #459
Hi nikhilji
thanks
Thanks Quanqhao! Finally got the right voltages for B+ and the SSHV is working as expected and no overheating of heatsinks. I have both the SSHV and D3A phono board in one single chassis using a R-Core power transformer and shielded hookup wire. Needless to say, the sounds is clear and detailed with no low-frequency hum ! I'm impressed.
Old 6th May 2012, 08:41 PM   #460
I'm enjoying the music coming out from this phono stage. Thanks to Quanghao, Salas and Andrea. Truly a global collaborative effort for the enjoyment of the diyaudio community.
Posting some pics :
OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas)Hide this!Advertise here!
Simplistic Mosfet HV Shunt Regs Salas Power Supplies 5765 30th September 2017 04:53 PM
About the Simplistic Mosfet HV Shunt group by quanghao Quanghao Audio Design 7 18th July 2010 03:31 AM
Copyright ©1999-2017 diyAudio
