Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 16th March 2010, 11:51 AM   #121
adamus is offline adamus  United Kingdom
Please Update the list yourselves when you type:
1. Jogi = 2PCB
2. qusp= 2-3PCB
3. Bas Horneman = 2 PCB
4. hihopes = 2PCB
5. guglielmope = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
12.jameshillj = 2 pcb
13.dodo = 1 pcb (one)
14.normundss = 2-3 PCB
15. stoolpigeon 4 PCB
16. Nikon1975 = 2 PCB
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 1 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
22. av-trouvaille = 6-8 pcb
23. Jean-Charles = 4 pcb
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
27. Joshua_G = 1 PCB
28. ernesternest 2 PCB
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 3 pcb
32. housing = 2 pcb
33. h-wan = 1 pcb
34. ichiban = 2 pcb
35. Adamus = 1 pcb
36. mikel_ann = 2 pcb
37. flyboi = 2 pcb
38. ims = 1 pcb
39. touchdown = 1 PCB
edited to 1 pcb, i didnt realise 1pcb = two boards. thanks
Old 16th March 2010, 12:01 PM   #122
regal is offline regal  United States
Originally Posted by quanghao View Post
Simpler Simplistic design by Salas
[on the 22-3 production was finished 2 – 4 - 2010
Then I will send the first day for all of you!
Not sure I understand the lead time, you're not saying it took 11 months to make the boards?
Old 16th March 2010, 12:02 PM   #123
two weeks surely?
Old 16th March 2010, 12:05 PM   #124
Yunick is offline Yunick  Sweden
Paypal sent!
Old 16th March 2010, 12:12 PM   #125
gabanyayaya is offline gabanyayaya  Malaysia
In this Tube (6n2 or 12AX), use some mA. you can use one suppy for it.
But i dont like SRPP for DAC, i fin in my house, if i still have PCb SRPP, i will gift you, don't pay money.
quanghao
If SRPP not good for DAC output can you suggest something better than SRPP and can use Simplistic Mosfet HV Shunt as PSU.
Originally Posted by regal View Post
SRPP sounds awful in a DAC, it is very load dependant. Just use a low Rp high gain tube in bypassed cathode with output from the anode. Use 6n6p or 5842 (for more gain), sounds much better than a SRPP, trust me I've tried many tube DAC stages.
regal
What do you propose other than SRPP??
Old 16th March 2010, 12:15 PM   #126
Originally Posted by noizas View Post
quanghao
Can I make Paypal transfer for 3 PCB in amount 3x30 USD, or I need to wait some options for postage cost?
Concerning gabanyayaya SRPP schematic - it shows like I/V ala Lampizator with 6N2P - one solution for I/V, amp and even buffer. If here is question of space in box, it is not worst solution, IMHO.
What is wrong with SRPP as I/V - can you share your experience?
gabanyayaya
Indeed you can use one shunt regulator as power suplly, but better substitute by it only diodes D1-D4 - leaving RC filters separate for L and R channels. This would be reasonable because even SRPP's upper tube works as CCS, this is true only if SRPP designed well - matched on specific Rload.
You can read about it here - The Tube CAD Journal,SRPP Decoded .
If you need to calculate SRPP, just please write me - s.navikas@zebra.lt, I will do it with TubeCAD for my pleasure.
So you saying SRPP only need a simple PSU like CRC filter....rather than the shunt...?
Old 16th March 2010, 12:17 PM   #127
Originally Posted by gabanyayaya View Post
quanghao
regal
You may have to use a different tube depending on gain required.
Old 16th March 2010, 12:26 PM   #128
Why use LED ? What type?
Do you use a variable R next to 1000R ? So basically this + the shunt sound better than lampizapor ?
Old 16th March 2010, 12:33 PM   #129
led bias is just another way of biasing the grid. the yellow LED will bias to 2v or so, just watch the current ratings, 22ma is quite hot for an LED.
leds have low dynamic resistance, so no need for electrolytic bypass caps as with resistors. less crap in the signal chain.
Old 16th March 2010, 12:39 PM   #130
quanghao is offline quanghao  Viet Nam
OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas) Send a message via Yahoo to quanghao OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas)
the sound is not good!
I always said that additional sources of energy affect 40% of sound quality. And I love power shunt.
OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas)Hide this!Advertise here!
Simplistic Mosfet HV Shunt Regs Salas Power Supplies 5805 8th February 2018 07:52 AM
About the Simplistic Mosfet HV Shunt group by quanghao Quanghao Audio Design 7 18th July 2010 04:31 AM
