Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 16th March 2010, 12:33 PM   #131
regal is offline regal  United States
Originally Posted by gabanyayaya View Post
Do you use a variable R next to 1000R ? So basically this + the shunt sound better than lampizapor ?
Yes read Salas's 10m45s thread that explains how to set up a CCS. You can get LED's that handle 20+ mA's fine just look at the datasheets. You may want to use a 5842/6c45pi tube for higher gain so you can use a lower I/V resistor. You have to be able to calculate final output to set this up for a DAC and yes it sounds much better than an SRPP, its single ended without cathode output. If you google 6c45pi TDA1541 you will see that most of the orient has switched to this sort of stage rather than SRPP.
Old 16th March 2010, 12:37 PM   #132
Can you please post a link to Salas's 10m45s thread?
Old 16th March 2010, 12:42 PM   #133
grufti is offline grufti  United States
wombat
grufti's Avatar
Please Update the list yourselves when you type:
1. Jogi = 2PCB
2. qusp= 2-3PCB
3. Bas Horneman = 2 PCB
4. hihopes = 2PCB
5. guglielmope = 2PCB
6. Ryssen = 2PCB
7. kstlfido = 6PCB
8.cygnus x1 = 8PCB
9. regal = 4PCB
10. le`flu = 4 PCB
11. vgeorge = 2 pcb
12.jameshillj = 2 pcb
13.dodo = 1 pcb (one)
14.normundss = 2-3 PCB
15. stoolpigeon 4 PCB
16. Nikon1975 = 2 PCB
17. pchw = 4 pcb
18. boudy = 2 PCB
19. Yunick = 1 PCB
20. JimS = 4PC
21. Cambe = 3 PCB
22. av-trouvaille = 6-8 pcb
23. Jean-Charles = 4 pcb
24. Ferrari = 4 PCB
25. piero7 = 2 pcb
26. Zekk needs ONE
27. Joshua_G = 1 PCB
28. ernesternest 2 PCB
29. wobii = 2 pcb
30. Jaap = 2 pcb
31. noizas = 3 pcb
32. housing = 2 pcb
33. h-wan = 1 pcb
34. ichiban = 2 pcb
35. Adamus = 1 pcb
36. mikel_ann = 2 pcb
37. flyboi = 2 pcb
38. ims = 1 pcb
39. touchdown = 1 PCB
40. grufti = 2 PCB
added 2 pcb. thanks
Old 16th March 2010, 12:53 PM   #134
noizas is offline noizas  Lithuania
So you saying SRPP only need a simple PSU like CRC filter....rather than the shunt...?
No, I had idea that you can use one shunt regulator for both channels, separating power supply for L and R channels via CRC filters (like in your drawing).
Theoretically this is ok, as BALANCED SRPP uses constant current.
Balanced SRPP means, that output capacitor is loaded with load, for that was calculated - LOAD IS PART OF SRPP!
So if you are loading SRPP not exactly R you are designed for, you will have non A class here - distortion.
So two shunt regulators are exactly in place with SRPP, when those are NONbalanced
Seriously would recommend you to use SE for I/V stage - plate follower or grounded cathode. Or even better mumetal transformer, but this is another story...
Old 16th March 2010, 01:24 PM   #135
piero7 is offline piero7  Italy
piero7's Avatar
Originally Posted by quanghao View Post
Simpler Simplistic design by Salas
A. Information about Salas shunt:
Simplistic Mosfet HV Shunt Regs
Thank you Salas
_______________
B. Information PCB
+ One PCB:
2 x Simpler Simplistic
2 x Heater Power Supply+ Quality:
two layers , gold-plated, 1.6 mm thickness
C. The price includes:
PCB + Shipping (surface mail) + fee PayPal :
1. PCB = 30$
2. PCB = 55$
3. PCB = 85$
4. PCB = 110$
Hi everyone. Current everything I was ready to submit designs for manufacturers to make circuits.
So you have registered, please let me transfer the funds to my order soon.
Time to receive funding to start from today to 16-3-2010
When I receiving funding will be made immediately,
on the 22-3 production was finished 2 – 4 - 2010
Then I will send the first day for all of you!
Thank you and please transfer money to my account
My papal account: quanghao168@yahoo.com.vn
quanghao from 15$ each pcb as you wrote me in MP now the price is just double, don't you think it's a bit too much for surface mail?
Old 16th March 2010, 01:25 PM   #136
$30 U.S. is dear, very dear for a PCB.
What's going on here?
Old 16th March 2010, 02:01 PM   #137
30 USD for 2 x simpler simplistic + 2 x filament PSU regulator, totally 125mmx 250mm PCB, is not so expensive, IMHO.
Same size, but not gold plated bare regular PCB in ebay shops costs 15 - 22 USD even without delivery cost.
Here we have delivery and Paypal fee already included.
And this is not regular production of bare PCB...
Old 16th March 2010, 02:50 PM   #138
I like the circuit just now, simple to build but I have a V-out DAC...witht is work?
Old 16th March 2010, 03:17 PM   #139
Schematic that you provided us is compatible with low signal I-out DAC as TDA1541, AD1865, etc (just different R I/V needed). It is simply too high gain for V out type DACs with 1 - 2V RMS ready.
For V-out DAC with opamp V output ready I would use cathode or anode follower, based on 6N6P or something like that valve. Schematic and calculation you can find in lampizator site, just google "lampizator 6N6P".
If supply voltage or tube type is not ok for you, let me know, I can help with calculations.
However take care - Vout as usual is worse approach, than I -out (except few TDA, AD and Wolfson DAC). And you will have one more capacitor in chain.
So the sound can be not so natural, IMHO.
Old 16th March 2010, 03:30 PM   #140
adamus is offline adamus  United Kingdom
not really, it will have too much gain.
EDIT - beaten to it with a much better answer....
Simplistic Mosfet HV Shunt Regs Salas Power Supplies 3947 21st May 2013 07:43 PM
About the Simplistic Mosfet HV Shunt group by quanghao Quanghao Audio Design 7 18th July 2010 03:31 AM
Copyright ©1999-2013 diyAudio
