Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 31st July 2010, 02:45 PM   #261
John Caswell is offline John Caswell  United Kingdom
Default Phono/Regulator PCB
Hi Quanghao,
Address etc already sent via private mail.
John Caswell
Old 31st July 2010, 02:45 PM   #262
klaju1955 is offline klaju1955  Brazil
Originally Posted by quanghao View Post
Hello!
The PCB is you do not get me very sad thing, and I'll send for you again. PCB hopes will hand to you, no destination Most PCB is not your phone number. I work with prestige, not profit. If you move to make sure, faster, and make sure to place it very expensive.
I've used
You did not get the PCB address please send me an e-mail with the following information:
Name:
Address:
Phone:
Nick DIY:
PCB name:
Extremely thank
Hello Quang Hao,
I think it would be a good idea give the people the posted/tracking number of the letters, I dont know how the post system works in other countries,
here in Brazil I can see exactly the ariving and way of your letters in Brazil, but only after receiving the letter when I saw the number on it.
Sometimes have a delay in the customs or goes a wrong way, when you can see it post tracking system you have time to speak with the post.
Klaus
Old 31st July 2010, 02:56 PM   #263
quanghao is offline quanghao  Viet Nam
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli Send a message via Yahoo to quanghao OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli
Hi klaju1955 !
Yes that is fine, some country can check it!
Tomorrow i can sent it! Thanks
Old 31st July 2010, 03:00 PM   #264
Hi klaju1955 !
Thank you Quang Hao,
not for me, I have allready received the set, perhaps it helps John or others who did not received till now.
But in the future I think is good you send to everyone per Email the package number.
Klaus
Old 1st August 2010, 03:17 PM   #265
Hello!
After I finished 4 phono, my favorite is the sound of it, so Andrea has recalculated the values in the circuit. I was very interested in these calculations. Motherboard I do for you called a phono ASH.
Today, I use 50 ohm resistors cadoc for cathode tube D3A , and 0.68 UF capacitor output Jensen. Sounds great.
I had a chance to compare with the EAR 834 phono
Phono D3A (ASH) te sound is better 834,
and I like D3A phono in the following points:
The sound, balanced, very high resolution, Nature
No noise,
Probably due to light interference is very small electronic D3A
SO it is very good Phono.
Old 1st August 2010, 03:34 PM   #266
Default The next week i will ship agian PCB Phono To you
Name:
Address:
Phone:
Nick DIY:
PCB name:
Phono D3A PCBs not arrived :
1. johngalt47
2. 2. vanofmonks
3. John Caswell
4. alex1946audio
5. Torsken
Any more, Can tell me please!
Thank!
Old 3rd August 2010, 07:08 AM   #267
tangmonster is offline tangmonster  South Africa
tangmonster's Avatar
All i still need before the power supply test is my 120k 2W resistor.
I also need better screws for the heat sinks and i need to put in isolating washers so that the heat sinks are not live.
After the power supply is tested i will connect it to the phono part and test. YAY!!
I decided to mount my large capacitors underneath so when i design my enclosure i can easily make my tubes protrude at the top for a classic look. On too Autocad!!
Old 3rd August 2010, 10:59 AM   #268
Hi Tang,
It goes looking fine, Im also was thinking to make a cabriolet version and perhaps separate the power part in another chassis.
But Im just looking around for buying the parts, where do you bought yours, in a thread you told for making a list?
Klaus
Old 3rd August 2010, 12:21 PM   #269
Here is my Bill of materials so far.
I bought all the "funny" parts from rs components. The rest of the "standard" parts you can find very easily at any electronics shop.
Some parts have the RS part number that I used next to it.
I have added notes with the errors i have found so far.
PLEASE NOTE:
I used the original RIAA circuit with 33nF and 100nF I DID NOT USE THE EXPENSIVE silver mica riaa circuit. You will have to change the RIAA resistors and capacitors too your needs.
I have not tested my setup. Only finished soldering last night. I will test within this week.
Good luck
Tang
File Type: zip tangmonster 3-8-2010 Bill of Materials with notes.zip (7.0 KB, 113 views)
Old 3rd August 2010, 12:24 PM   #270
There is probably still mistakes with my bill of materials.
please let me know if you found any and then i will fix it and update
OLD THREAD Hi-end phono preamplifier by Andrea CiuffoliHide this!Advertise here!
OLD THREAD DAC End by Andrea Ciuffoli quanghao Quanghao Audio Design 2063 21st March 2015 10:25 AM
Hi-end phono preamplifier quanghao Quanghao Audio Design 8 30th June 2010 04:37 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright ©1999-2017 diyAudio
