Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 27th July 2010, 06:45 AM   #251
tangmonster is offline tangmonster  South Africa
tangmonster's Avatar
The zener diodes are all a bit flakey
I got 1n4742 as johngalt47 suggested
But this is a whole lot better.
I have another question.
In the quanhoa's design on the phono board R22 and R23 is 820k. But on the original design it is 1M. If i want to try the original riaa circuit should i use 820k or 1M? Or does it not matter?
Old 27th July 2010, 06:53 AM   #252
quanghao is offline quanghao  Viet Nam
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli Send a message via Yahoo to quanghao OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli
that is 820K//, no 1 M!
Old 27th July 2010, 06:58 AM   #253
So even if i use the original riaa circuit with mkp 100nF and 33nF I must still use 820k?
Old 27th July 2010, 07:42 AM   #254
Yes! you can keep it!
Old 27th July 2010, 12:41 PM   #255
alex1946audio is offline alex1946audio  Italy
Default Phono D3A PCBs
Originally Posted by quanghao View Post
please let me know if you have not received PCB phono ASH
A. Phono D3A PCBs arrived :
1. pred
2. johngalt47
3. guglielmope
4. Loboone
5.johngalt47
6.tangmonster
7. Pilsern
8. jormajj
9.khaho
10. klaju1955
Phono D3A PCBs not arrived :
1. johngalt47
2. 2. vanofmonks
3. John Caswell
4. alex1946audio
5. Torsken
I don't have received yet the boards
Old 29th July 2010, 12:41 PM   #256
klaju1955 is offline klaju1955  Brazil
Hi Tang,
Im not a krack in electronics, but if I understand it right, the 1M resistor is going into the RIAA network calculation.
Have a look at the Andreas side Audio Design Guide, there is on Phono 4 the calculator with the exact values, or ask Andrea himself.
Klaus
Old 29th July 2010, 02:27 PM   #257
You are indeed correct!!!
Thanks man. That will teach me to ask questions and just blindingly trust other people. :P
NO I can't keep it quanghao.
Old 29th July 2010, 03:45 PM   #258
klaju1955 , tangmonster
Audiodesign will answer you, when he comes back!
New the value and the circuit, i was sent to you, Audiodesign was calculate and i test 2 option, and i like new the value.
About the 1M//. or 820//. he like 2 x 820K( parallel)
Quanghao
Old 30th July 2010, 04:20 PM   #259
John Caswell is offline John Caswell  United Kingdom
Default Despatch of replacement phono PCB
Hi Quanghao,
Have you any idea when you will despatch the replacement phono PCBs for those of us who have not received them yet?
John Caswell
Old 31st July 2010, 01:55 AM   #260
Hello!
The PCB is you do not get me very sad thing, and I'll send for you again. PCB hopes will hand to you, no destination Most PCB is not your phone number. I work with prestige, not profit. If you move to make sure, faster, and make sure to place it very expensive.
I've used
You did not get the PCB address please send me an e-mail with the following information:
Name:
Address:
Phone:
Nick DIY:
PCB name:
Extremely thank
OLD THREAD Hi-end phono preamplifier by Andrea CiuffoliHide this!Advertise here!
OLD THREAD DAC End by Andrea Ciuffoli quanghao Quanghao Audio Design 2063 21st March 2015 09:25 AM
Hi-end phono preamplifier quanghao Quanghao Audio Design 8 30th June 2010 03:37 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
