Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 26th July 2010, 12:48 PM   #241
tangmonster is offline tangmonster  South Africa
tangmonster's Avatar
ok ,son in the input ground and in is swopped on the silkscreen.
But I am not sure i understand what is going on with those two 50R resistors?
Old 26th July 2010, 01:41 PM   #242
klaju1955 is offline klaju1955  Brazil
They are the catode R of V2 and V4= R32 and R50
Old 26th July 2010, 02:11 PM   #243
Yes , but in the drawing it seems like you must not populate both but on 50R across the two ??
I guess nothing changes and only 2 must be populated?
Old 26th July 2010, 02:24 PM   #244
johngalt47 is offline johngalt47  United States
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli
Default changes?
I'm starting to feel uneasy about this board. Is there anyway we can have all the changes/problems/answers in one message?
Any technology sufficiently advanced is indistinguishable from magic
Old 26th July 2010, 03:02 PM   #245
ME too
but so far I am building a file with a full parts list and also a list of errors.
I ordered all my parts today so early next week i will assemble.
Obviously I will assemble the power supply first.
On the previous page you can see the errors I found with the ref designators of the power supply. When I populate the parts I will double check everything and try and make a post with all my findings so that we all have one place with all the errors.
I will post my bill of materials ,it might help some people.
Note also. I did not go for the VERY expensive silver Mica capacitors.
I am going to build mine according to the RIAA circuit of the original schematic.
using 100nF and 33nf caps.
Old 26th July 2010, 03:41 PM   #246
You mean the parallel R32a and R50a, I think Qaung Hao have let a spare
for????, perhaps additional cap...
Old 26th July 2010, 04:47 PM   #247
no not talking about parallel
the way he has the 50R over the two resistors in series makes it confusing. don't worry , it's probably just me. Fact is you need to populate 4 x 100r to get 50r per side.
Old 27th July 2010, 02:26 AM   #248
quanghao is offline quanghao  Viet Nam
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli Send a message via Yahoo to quanghao OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli
Default Information about the value of Phono D3A
Hello, the value of individual components in this diagram as phono 4. But Andrea has calculated value, and I did a comparison between them, the new value shows better, so the new diagram below. All the capacitors and resistors are not recorded values for an option in parallel. I'm sorry that was not clear for you to understand. Thanks
Phono 4 cricuit
Old 27th July 2010, 02:38 AM   #249
Default the new value of Phono 4
the new value of Phono 4 , i call Phono ASH
this is cricuit and PCB
Old 27th July 2010, 02:56 AM   #250
Default Salas for Phono D3A (ASH)
The cricuit SSHV for Phono D3A (ASH) and BOARD CONFIGURATION SETTINGS
OLD THREAD Hi-end phono preamplifier by Andrea CiuffoliHide this!Advertise here!
OLD THREAD DAC End by Andrea Ciuffoli quanghao Quanghao Audio Design 2063 21st March 2015 10:25 AM
Hi-end phono preamplifier quanghao Quanghao Audio Design 8 30th June 2010 04:37 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
