| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#371 |
!it is near the cap 220uF!
http://www.audiodesignguide.com |
#372 |
#373 |
Yes it does have on board! but you weld it at the bottom capacitor 220uF 2 children, or no longer needed! it only to discharge the voltage!
#374 |
Hello,
Is still possible to buy the phono + PS pcb? Thanks |
#375 |
yeS! i stil have some PCB
Thanks Quanghao
#376 |
#377 |
What is the Cag value of D3A tube in triode connect?
#378 | |
Cheers, Frd |
#380 |
Hello,
is it still possible to buy a phono stage and and a shunt regulator. If i ngo on Quanghao it tells me no carrier to germany or switzerland?!! Kind regards, Michael |
| OLD THREAD DAC End by Andrea Ciuffoli | quanghao | Quanghao Audio Design | 2028 | 6th March 2012 12:04 AM |
| Hi-end phono preamplifier | quanghao | Quanghao Audio Design | 8 | 30th June 2010 03:37 AM |
| The DAC End 2 by Andrea Ciuffoli pcb + most parts... | prooptiki | Swap Meet | 7 | 31st May 2010 02:21 AM |
| Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... | zxcxz | Tubes / Valves | 2 | 10th July 2009 04:14 PM |
| Andrea Ciuffoli Mosfet Amp | DieterD | Solid State | 16 | 24th December 2001 05:56 AM |
| Page generated in 0.10791 seconds (75.47% PHP - 24.53% MySQL) with 11 queries |
