OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli - Page 36 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 25th October 2010, 02:32 PM   #351
Originally Posted by tangmonster View Post
I have designed an enclosure for this preamp.
I will post more pictures of assembly when I get the metal back net week
This will house both pc boards and an alps slider potentiometer.
The open sides will be closed with wood.
looks great Tang, very professional, Im looking forward for see it finished.
Klaus
Old 25th October 2010, 09:31 PM   #352
Default Phono/Regulator PCB
Hi Quanghao and others,
Yes I have received the PCBs as I said, and am in the process of building them, but other work keeps getting in the way and the need to earn money is very high at present.
I am initially just going to build the phono stage as I already have a PSU that will be suitable. My idea is to put it in a diecast Hammond box at first to sort out any assembly/wiring/component problems and then get a custom enclosure made by a friend as I will need to add some moving coil step up txs probably Sowter 8055s. Hopefully will take some pictures and put them up here.
John
Old 28th October 2010, 05:48 AM   #353
tangmonster's Avatar
Klaus
Thanks! ,here is the latest progress , Got the metalwork yesterday. All my previous projects I used natural anodized Alu , but for this one I tried brushed 430 Stainless steel:
Old 14th November 2010, 08:45 AM   #354
Working great!
I was scared about the transformer and everything being so close together in one enclosure but luckily no hums or other noises.
Old 6th January 2011, 07:48 AM   #355
pred is offline pred  Switzerland
Hello all,
I am starting to build mine. Yes I know it is almost a year after the PCBs have been made, but you know not enough time, small kids and all
I see there are some errors on the board that have been found, and also that there are two versions of RIAA corrections. Quandhao, would you be so kind to post the last schematic for RIAA and regulator please, so that I am sure on what I am to build. Also would you post in the same place where to take care on errors of the PCB.
Thank you in advance,
Pred
Old 20th February 2011, 04:37 AM   #356
Strosek is offline Strosek  Canada
Quanghao, do you still have any boards? Also please check your email I sent you a question about Dac-ash.
Old 23rd February 2011, 04:26 PM   #357
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
A "final" (corrected) update would be great !
Arne K
Don't believe everything you think...
Old 27th February 2011, 10:05 AM   #358
gioz is offline gioz  Italy
gioz's Avatar
What's the difference from old and new?
Phono - Quanghao.com
Old 11th March 2011, 08:38 AM   #359
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Hi!
I still have some PCB Phono! Pleas sent to me E-mail again???
Old 11th March 2011, 08:40 AM   #360
HI! no difference!
OLD THREAD DAC End by Andrea Ciuffoli quanghao Quanghao Audio Design 2063 21st March 2015 09:25 AM
Hi-end phono preamplifier quanghao Quanghao Audio Design 8 30th June 2010 03:37 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright 1999-2017 diyAudio
