OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli - Page 29 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 4th August 2010, 03:50 PM   #281
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by tangmonster View Post
R1 = 22r = 16V drop
R1 = 1k = 67V drop
R1 = 500R 20W= 35V drop = 65C
irf840 = 50C
irf9610 = 60C
I suppose i am going to
Is 60C ok for irf9610? or is it too high?
60 C , it is ok for 9610, 840
how many voltage drop Irf 9610??
And you AC = ???
Old 4th August 2010, 03:59 PM   #282
tangmonster's Avatar
yes , but my transformer is sitting at 57C due to all the wasted heat.
lm317 sitting at 75C
I am going to have to lower primary voltage or get different transformer
sigh
230V ac and 9v AC is WAY to high for this circuit.....
Old 4th August 2010, 04:12 PM   #283
sigh
yes! 230vAC~290VDC, so R1= 50V, and 9610 = 40V drop, i calculate max for it!
and now i use that! You can down VAC min = 200V, so down R1, it is low
Old 4th August 2010, 04:17 PM   #284
Originally Posted by quanghao View Post
yes, it is ok. 230 x 1.28 = 294v, +b need 200 v , i= 40ma, ok,
you said it was ok!!!!!!!!!!
Don"t look for excuses now!!!???
Old 4th August 2010, 04:21 PM   #285
ALL YOUR DRAWINGS SHOW 220 to 250V AC???????
Heater circuit 7 to 9V AC???
Old 4th August 2010, 04:40 PM   #286
Hello Andrea,
I'm building the circuit, but I'm thinking about the change of the anode resistors (//22K) with a ccs like cascode DN2540.
What do you think about? The Riaa circuit needs any adjustement?
Thanks a lot for you help.
Ciao
Guglielmo
Old 4th August 2010, 10:10 PM   #287
pred is offline pred  Switzerland
In my days it was 230VAC is 320VDC (factor of 1.41) but maybe this changed over time I think it is too high
For heater you need min 7V since it is 9.87VDC-1.5V drop for diodes so you get 8.3. So then you will have minimum required drop for LM317 that is 2V.
Pred
Old 5th August 2010, 02:41 AM   #288
Hi tangmonster, and all!
Well I have calculated wrong for you, I apologize, thank you just for me!
Hope you always help me find my mistakes, to my product for you to be more perfect.
Old 5th August 2010, 02:46 AM   #289
Default Use center transformer for SSHV
if you have transformer: 200-0-200 V you can use PCB
you se in the image
Old 5th August 2010, 07:22 AM   #290
200V Ac will give 282V dc That is still a 82V drop.
I think you can safely drop the 200Vac to 180Vac(254Vdc)
With 9Vac my lm317 is sitting at 75C which is too high. Using a 6.7c/w heatsink.
Long story short I will need to get a different transformer......
170Vac and 7Vac should do nicely
For now I am going to experiment with a 10ohm 50W resistor on the primary of the transformer to drop input and output voltages
OLD THREAD DAC End by Andrea Ciuffoli quanghao Quanghao Audio Design 2063 21st March 2015 10:25 AM
Hi-end phono preamplifier quanghao Quanghao Audio Design 8 30th June 2010 04:37 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright 1999-2017 diyAudio
