Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 5th February 2010, 01:10 AM   #491
toufu is offline toufu  United States
How critical are the Sanyo Os-Con caps? Can't we just use something decent like Panasonic FC's?
Old 5th February 2010, 01:15 AM   #492
quanghao is offline quanghao  Viet Nam
OLD THREAD DAC End by Andrea Ciuffoli Send a message via Yahoo to quanghao OLD THREAD DAC End by Andrea Ciuffoli
[QUOTE=rtd;2074046]There is 3 small area behind the CS8414, the AD1865 and the 74Hcxx but not "wide enough" to form a large groundplane.
It is on the top layer!
You can use L for R 10Ohm!
thank
Old 5th February 2010, 01:37 AM   #493
in the Board DAC-end you do not use other Cap, only Sanyo Os-con! you can ask Andrea!
In the Salas shunt you can use other Cap! with one If you like!
Old 5th February 2010, 03:23 AM   #494
agithegreat is offline agithegreat  United Kingdom
Is there a finalized parts list up yet (BOM)?
Or should we take the parts as shown here: DAC End 2 - the AD1865N-K with single ended vacuum output stage
Old 5th February 2010, 04:05 AM   #495
This Board of DAC
Old 5th February 2010, 05:00 AM   #496
apelizzo is offline apelizzo  Australia
apelizzo's Avatar
You could, but I would say NO because Oscon is unique (special) cap and is the best for digital signal decoupling. On the analog though you could use something else like Elna Silmic for example.
Oscon SP is best for this purpose then SH.
Oscon SP around 220uF is easy to get from eBay while I cannot find the 47uF SP 16V
Anyone can help to find Oscon 47uF 16V SP series please? I can only find SA
Old 5th February 2010, 05:04 AM   #497
apelizzo's Avatar
Quanghao,
where did you find 47uF 16V Oscon? Are they SP series?
Farnell got them in stock at $8.00 each !!! Too expensive
Old 5th February 2010, 05:58 AM   #498
Originally Posted by apelizzo View Post
Quanghao,
Yes! diffical fine 47uf 16v
Old 5th February 2010, 06:28 AM   #499
audiodesign is offline audiodesign  Italy
Banned
Send a message via MSN to audiodesign OLD THREAD DAC End by Andrea Ciuffoli
The secondary for the filaments should be 8v 3A instead of 9v 1A.
and the 2 x 2.2ohm 3w resistor should be 2.2ohm 5w
Old 5th February 2010, 06:30 AM   #500
Banned
Os-con 47uF 16v
SANYO OSCON SA Series 47uF 16V 16SA47M (lot of 15) su eBay.it Electronic Components, Electrical Test Equipment, Business Industrial
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright ©1999-2017 diyAudio
