Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 24th October 2012, 09:48 AM   #2031
Alchamist is online now Alchamist
Alchamist's Avatar
Default Dac End 2
Hi how can i buy dac end 2 , I/V stage and power supply pcbs ? Could you tell me a way ? Is it still possible ?
DAC End 2 - the AD1865N-K with single ended vacuum output stage
Best Regards
Old 24th October 2012, 11:23 AM   #2032
sigurd is offline sigurd  Belgium
Best Regards
I have asked that too, but no answer...
Old 27th October 2012, 08:17 PM   #2033
hotzman is offline hotzman  Romania
Hi Yildiray,
Quanghao is hard to find!!!
If you are interested, I am selling a DAC END 2 PCB! Only digital PCB.
Or if you want I can sell you almost completely DAC END 2 with hi-end audio components, LESS!!! AD 1865, CS8414, 74HC04, R37/38(200R) and C38,39(10nF). Remaining components are Nichicon, OS-CON, Wima Black Box ,Vishay capacitors, MUR ultra fast rectifier, Kiwame, RPR resistors!
Now I listen to DAC END 3, but no major difference!
Send me a PM. Will send you pictures!
Regards!
Old 28th October 2012, 02:52 AM   #2034
Hi Hotzman,
Can I buy digital PCB DAC END 2 ?
Old 28th October 2012, 11:42 AM   #2035
Yes Sidurd, send me PM for detail!
Old 14th December 2012, 05:27 PM   #2036
cabašo is offline cabašo  Portugal
Hi Hotzman,
I send you pm for the almost completely DAC END 2.
Best regards
Old 10th February 2013, 09:57 PM   #2037
jabrzoza is offline jabrzoza
Hi.
Does anybody have a spare PCB for AD1865 DAC END, digital would be enough.
As many of you I sent couple of messages to Quanghao, but with no answer.
Lukasz
Old 10th March 2013, 07:16 PM   #2038
UP! :-)
Old 21st April 2013, 06:26 AM   #2039
Tyimo is offline Tyimo  Hungary
Hi!
I would like to ask about the phase jumper on the DAC END2 board.
On the layout photo I can see "in phase" connected to the 11th leg of the 74HC04 chip, but on the schematic this connection is named to "outphase". So which one is correct???
greets:
Tyimo
Old 22nd July 2013, 04:56 AM   #2040
cucuclock is offline cucuclock  France
Default ad1865 dac
it looks its impossible to contact Quanghao, even by his site, does someone has a end dac pcb to sell?
thank you
vito
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright ©1999-2017 diyAudio
