Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 6th August 2010, 04:55 AM   #1941
quanghao is offline quanghao  Viet Nam
OLD THREAD DAC End by Andrea Ciuffoli Send a message via Yahoo to quanghao OLD THREAD DAC End by Andrea Ciuffoli
Hi pathetic
Mundorf Supreme 1uf Mcap for the I / V that is very good! but not necessary for SSHV, waste too!
Im wrong it, Shunt diodes for low Salas for special, select the type equivalent
Thank
Old 6th August 2010, 05:03 AM   #1942
flocchini is offline flocchini  United States
Originally Posted by quanghao View Post
Hi klaju1955
Do not separate between SSHV and I / and E182CC wit transformer output, I will send you the following diagram.
You're signing on to the list! Thanks for the interest.
Quanghao
Can you post this diagram?
Bob
Old 6th August 2010, 05:22 AM   #1943
pathetic is offline pathetic  Australia
Hi pathetic
Thank
I'm not quite clear on this. Do I use 1N5819 or 1N5062 for the DAC updated?
Thanks quanghao.
Old 6th August 2010, 06:19 AM   #1944
Thanks quanghao.
You use 1N5819.
Old 6th August 2010, 11:43 PM   #1945
ben-jam-in is offline ben-jam-in  Canada
ben-jam-in's Avatar
Originally Posted by klaju1955 View Post
I received, thank you Quang Hao
14. ben-jam-in
received boards, thanks!!
Old 7th August 2010, 05:16 PM   #1946
ThuyTN is offline ThuyTN
Send a message via Yahoo to ThuyTN
I have a couple of questions for those who have finished the DAC.
Did anyone try removing the filter (L1,L2 in the DAC and R30-33 in the IVY)? What difference should I expect if I do that?
Also, I'm thinking of switching some caps to Black Gate. The ones I'm replacing are the Sanyo 47uf. I'm having the OSCON SP there and might try the BG NX HiQ 47uf. Other caps are the 220uf in the IVY. Thinking of popping the BG N 100uf into there. What do you guys think about this? Is it worth replacing those caps?
Old 7th August 2010, 08:42 PM   #1947
Default Help
HELP
Problem with Salas HV
Using 0-250 Rcore -260V AC at input
250VDC after rectifier?
Have blown 2 9610s
THe 470 ohm resistors start smoking after 2 seconds. Obviously too much current
No obvious shorts on board.
Where do I start troubleshooting
Bob
Old 8th August 2010, 12:37 AM   #1948
hfar is offline hfar  Portugal
In my experience 2uF give me a litle thin sound (for comparation); with 4uF (each channel) this problem is in some way surpassed, the bass is more pronounced, more body, more solidity, more color. I take this detail quite seriously.
hfar
Old 8th August 2010, 03:30 AM   #1949
phrarod is offline phrarod  United States
hfar. Where are these caps going? Do you have numbers - C?
Old 8th August 2010, 05:24 AM   #1950
Default Output caps
pharaod, I'm sorry, my reply appeared out of the context.
I wonted reply to the "pathetic" #1940:
"Hey guys, about to order 1uf caps. I'm going to order 2 x 1uf Mundorf Mcap Supreme for the I/V. Was just wondering if I need premium caps for the Salas Shunt as well.(...)"
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright ©1999-2017 diyAudio
