Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 31st July 2010, 03:37 AM   #1921
flocchini is offline flocchini  United States
Thanks guys
Is the bleeder needed?
Old 31st July 2010, 03:43 AM   #1922
quanghao is offline quanghao  Viet Nam
OLD THREAD DAC End by Andrea Ciuffoli Send a message via Yahoo to quanghao OLD THREAD DAC End by Andrea Ciuffoli
Originally Posted by flocchini View Post
Thanks guys
Flochini
what does it mean??
Old 31st July 2010, 05:14 AM   #1923
Sorry Quanhao
Is R8 needed?
Is 270k good?
Old 31st July 2010, 05:30 AM   #1924
No need! R 8 = 270-470K, only protect you, and protect Cap 220uF when make Supply.
Old 31st July 2010, 06:20 AM   #1925
Got it.
Thanks Quanghao
Old 3rd August 2010, 02:30 AM   #1926
Hi all!
I plan to make PCB for i / v DAC use:
1. PCB use E182CC tube and output transformer.
In this link circuit:
http://www.audiodesignguide.com/DacEnd/index.html
2. Using A844 PCB Opam
What you are interested please subscribe to the list:
1..
Old 3rd August 2010, 02:32 AM   #1927
phrarod is offline phrarod  United States
Sounds very interesting. I always wanted to hear a good E182CC output stage. What output transformers are you using?
Old 3rd August 2010, 04:47 AM   #1928
Jeffrey Davison is offline Jeffrey Davison  United States
If I can use 6H30DR's and Sowter 9762's I'm in.
JD
Originally Posted by quanghao View Post
Hi all!
DAC End - the AD1865N-K with single ended vacuum output stage
1..
Old 3rd August 2010, 05:11 AM   #1929
pathetic is offline pathetic  Australia
The only place I can find the CCF50 Dale resistor is from mouser but minimum order is 5000. Is there anywhere else or other alternatives?
Old 3rd August 2010, 05:22 AM   #1930
You can buy som thing in this shop:
Holco Resistors
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright ©1999-2017 diyAudio
