Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 8th May 2010, 02:28 PM   #1601
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
OLD THREAD DAC End by Andrea Ciuffoli
Originally Posted by housing View Post
Iset=33R, old used part in the bin box.
Leave it there then, not that critical a position, and hey, has golden legs. Gold is back.
Old 8th May 2010, 02:33 PM   #1602
housing is offline housing  Hong Kong
Yes, that's an RMG, not RMA.
Old 8th May 2010, 02:34 PM   #1603
flocchini is offline flocchini  United States
Very nice build.
Where did you secure the HV shunt board?
Did you try the Quanghao's HV board? (Sorry if I missed this)
Bob
Old 8th May 2010, 02:35 PM   #1604
Salas's Avatar
Good thing is that the production HV board works OK then? No problems? You must be the first fully testing it and presenting a photo here, yes?
Old 8th May 2010, 02:44 PM   #1605
Originally Posted by flocchini View Post
Very nice build.
Bob
Hi Bob,
I didn't order quanghao's original HV board but ordered his Salas shunt HV board right from the beginning.
Thanks,
housing
Old 8th May 2010, 02:51 PM   #1606
I think it's perfect. I will hook it up to an oscilloscope soon.
Old 8th May 2010, 03:31 PM   #1607
Nikon1975 is offline Nikon1975  Austria
Salas,
I still do not manage to bring the voltages more than 5.2 V for the positive and 5.1 V for the negatives. I think that my leds have a ref voltages too high. Could it be ? Which one can I try to replace to make a test ?
Thanks,
Davide
Old 8th May 2010, 03:43 PM   #1608
Salas's Avatar
This sounds like a low voltage reg question I suppose. Check output Mosfet's VGS at you max. If its not circa 4V, then your current is robbed by the TL431s and you need even lower Rset as I have learned reading this thread. If it is alone it works anyway. What value of resistor you got as Rset now?
Old 8th May 2010, 04:05 PM   #1609
Originally Posted by Nikon1975 View Post
Salas,
Thanks,
Davide
My measurements may be of help to you:
All LED's sag about 1.91volt - 1.92 volt each
All 2SK170BL's Idss = about 6.5mA
AC voltage in = 10 volt by multimeter
Use 24R 1W for +ve and -ve rail of analogue supply, voltage easily adjusted to 5.6 volt and doesn't sag with load.
Positive rail voltage across 24R=2.104 volt, CCS is about 87.7 mA
Negative rail voltage across 24R=2.056 volt, CCS is about 85.7 mA. So I add a 1K in parallel with the 24R to make the CCS more like 87.7 mA
Use 2x24R in parallel for the +5V digital supply, voltage easily adjusted to 5.6 volt without load (at 166.6 mA output already) but sags to 5.32 volts with load.
Voltage across 12R = 1.999 volts, CCS is about 166.6 mA
All voltage measurement after TL431 for the IC's consumption are fine and about 5 Volt.
Old 8th May 2010, 04:27 PM   #1610
Salas's Avatar
The +5V alone branch can be challenged for even more CCS setting I have gathered. What is its output Mosfet's VGS when feeding the DAC?
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
