Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 29th April 2010, 01:08 PM   #1531
adamus is offline adamus  United Kingdom
I'd change the 33r for 27r.
Try 8ohms for r13, but make sure the fets have heatsinks
Old 29th April 2010, 01:09 PM   #1532
Yunick is offline Yunick  Sweden
I have 11r and my mosfet is blistering hot! Even with heatsink..
Old 29th April 2010, 01:18 PM   #1533
it depends on the current through the resistor, tolerances count for a lot here.
Mine isnt that hot with 11r, i could get away with no heatsink.
Old 29th April 2010, 01:24 PM   #1534
ok.
I'll measure the current through the resistor tonight..
Old 29th April 2010, 02:20 PM   #1535
Nikon1975 is offline Nikon1975  Austria
Now I have 8.2 27 27
The Vgs differences increased, now I have 3.9 V, but not the output voltages. Could it be that my leds are forcing a too high reference voltages ?
Davide
Old 29th April 2010, 02:26 PM   #1536
it could be.
I wouldnt worry about it, once i hit about 5.3v, on the scope the output after the tl431 looks the same as those on 5.6v.
Old 29th April 2010, 02:47 PM   #1537
ksnider1 is offline ksnider1  United States
Originally Posted by Yunick View Post
Very nice!
I see you have Wima on the output of I/V. how do you like them?
I tried RIFA PHE426 1µf and liked it very much.
You have some good time ahead trying different mods
Best Regards
David
I like them, I'm surprise how well it plays. I want to try some Russian OTK PIO caps later on. I did A-B with my Y2 DAC and found that when using terminal blocks L input channel on I/V is R and R is L. Photo on my previous post is correct.
I also had jumper set to 1-2, I changed to 2-3.
Old 29th April 2010, 03:55 PM   #1538
tassosk is offline tassosk  Greece
I'm planning to use a custom made 80VA toroidal trafo with 3x12V. Will it be any problem for the Sallas reg or is better to use one 2x12V trafo for the +5V,-5V and one 1x12v for the +5V?
Old 29th April 2010, 06:29 PM   #1539
I thought I should post some pictures of my build.
I did as Adamus recomended and removed the inductors and added the "led-mod". I listened to the DAC standard and to me these mods made it suit my ears better.
I tried both E182CC and 5687 and prefer the E182CC. Also use Sprauge Hyrel Q 1µf output caps.
To me this DAC easily beat my old parallell tda1543 dac.
Thanks Quang hao, Andrea and Salas. Also thanks to everyone who contributed in this thread!
Old 29th April 2010, 11:22 PM   #1540
Default NOS E182CC Mullard
I got my DacEnd up and running yesterday. I had day off today and I'm playing music all day. I'm enjoying very much. I'm running with GE JAN 5687WB, I want to try E182CC. Where preferably in US I can get E182CC for reasonable price ?
I found on ebay:
"6N6P Double Triode, It is direct replacement of ECC99,E182CC"
but it's not, correct ?
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
