Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 23rd April 2010, 05:24 PM   #1491
housing is offline housing  Hong Kong
Originally Posted by Mas Penk View Post
I don't really know about the sonic difference but I hear no Difference...
About the filter I read somewhere that filter should be R=1K C=47nF... CMIIW
Yes, the data sheet says so.
Old 23rd April 2010, 05:41 PM   #1492
adamus is offline adamus  United Kingdom
Originally Posted by housing View Post
Hello Andrea,
What value of the output capacitor and Rload are you using? What's the minimum voltage of the output capacitor? Is 200V OK?
Regarding the jumper on the DAC board, is it correct to hard wire pin 1 & 3 and leave pin 2 untouched?
Thanks for your response in advance.
housing
200v is not ok.
you should always spec the output cap to be B+ with an extra margin. you need 300v or more caps. if something goes wrong you want the output cap to survive. You do not want 260v going to your next piece of kit!
Andrea is using a different operating point for the CCS. Using a CCS allows you to pick different operating points due to the horizontal load line created (Constant Current, so horizontal). The plate voltage is then just set by the grid bias.
for normal (not using the extra CCS PCB) then the 90v plate voltage is more suitable.
Old 23rd April 2010, 06:07 PM   #1493
Originally Posted by adamus View Post
200v is not ok.
Hello Adam,
Thanks for your explanation. I think I understand now.
Old 24th April 2010, 12:34 AM   #1494
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default AD 1865 N-K Group buy
Very sorry for a little distortion
For anyone who wants get The Real AD1865N-K
Please Order in this Group buys, just need 8 pcs order for 30
http://www.diyaudio.com/forums/group...ml#post2164277
Thank you
Old 24th April 2010, 08:37 PM   #1495
ksnider1 is offline ksnider1  United States
Default Irfp240pbf
Hi, mouser, digikey, newark, farnell are out of stock. Can I use IRFP250PBF instead IRFP240PBF ?
Old 24th April 2010, 10:21 PM   #1496
pop music is offline pop music  Italy
OLD THREAD DAC End by Andrea Ciuffoli
RS components
code 541-0660
Old 24th April 2010, 11:14 PM   #1497
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
No, too high Ciss and gfs to match the other side. Look for IRFP244, IRFP340.
Old 25th April 2010, 12:37 AM   #1498
Nikon1975 is offline Nikon1975  Austria
If the Salas HV regulator is used, how many I need ?
I guess I cannot put the rc filter for channel separation after the regulator.
Thanks,
Davide
Old 25th April 2010, 05:37 AM   #1499
Thanks pop music, Salas, I have to order some missing parts for my other projects. I found IRFP244PBF on mouser. I will let you know how it works out in few days.
Old 26th April 2010, 06:24 AM   #1500
fredlock is offline fredlock  United States
Originally Posted by audiodesign View Post
Fred,
where you don't see "filters and bypass caps" ?
Andrea,
Sorry, I meant L1 and L2 was omitted as well as C4, C5, C9 and C10.
Would this heater power supply for the phono preamp applicable to the DACend? The 2.2ohms resistors and the bridge rectifier are too hot, can't stand it. This might be better that the original one. Please advise.
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
