Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 10th April 2010, 11:26 AM   #1421
housing is offline housing  Hong Kong
Default Simplistic Mosfet HV Shunt
Does any member finish his 5687 I/V stage with the Simplistic Mosfet HV Shunt designed by quanghao? How much current and voltage should it be set?
Old 10th April 2010, 11:38 AM   #1422
Default Problematic I/V stage PCB
Hi quanghao,
I looked at ksnider1's I/V stage PCB that's clean with crispy copper traces and examined mine that arrived this morning. Why is mine so dirty and masked by something unknown, and the ground plane near R32/R33 is extremely deformed and distorted?
Old 10th April 2010, 06:45 PM   #1423
Ekkeri is offline Ekkeri  Finland
Originally Posted by housing View Post
...and the ground plane near R32/R33 is extremely deformed and distorted?
Mine is also deformed in that place, looks very similar.. There have been some other quality issues also, with Salas output pads if I remember right..
Old 10th April 2010, 11:04 PM   #1424
Jogi is offline Jogi  Germany
Very good question, as I am waiting for salas board. As far as I remember, 50V + are required for the shunt to work.
So which transformer secondary voltage do we need, does anyone have an idea?
Juergen
Old 11th April 2010, 12:33 AM   #1425
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
OLD THREAD DAC End by Andrea Ciuffoli
15V-25V Will still be OK.
Old 11th April 2010, 04:22 AM   #1426
ksnider1 is offline ksnider1  United States
Originally Posted by Yunick View Post
Nice work Ksnider1!
Very neat and tidy.
Thanks, I'm waiting for Salas shunt PCB for DAC now. I hope it's on the way by now.
Old 11th April 2010, 04:47 AM   #1427
erwincantona is offline erwincantona  Indonesia
Originally Posted by erwincantona View Post
Just sharing
My friend uses Nelson Pass D-1 (replacement for Supply + IV Stage) for my DAC End 2.
But it hasn't worked well. He said the problem is on D-1.
(He'll find what really happened later)
Sound output ( Right and Left channel) isn't at the same level.
After replacing IRF610, previous problem is gone...
now DAC sings equal volume at right & left channel
After 1 hours play few songs, the result (compare with just DAC+Salas Shunt):
soundtage get wider
thick vocal
low and high get more extend
But..... voice sounds a little bit stiff. Need more time to break in?
Old 11th April 2010, 09:15 AM   #1428
Nice. Seems D1's I/V is an alternative to the tube I/V.
Thanks. Would like to hear further progress.
soundtage get wider
thick vocal
Old 11th April 2010, 10:01 AM   #1429
FRUGIVO is offline FRUGIVO  Spain
Hi Quanghao,I need full board (DAC END, Salas shunt for DAC, I/V stage and PSU for I/V Stage)I will wait until your PCB for PSU for I/V is ready.Thanks.
Old 11th April 2010, 10:54 PM   #1430
flocchini is offline flocchini  United States
I have altered my unit so that it is now using Welborne's PS10 power supply. It is regulated and uses no electrolytics. 267 volts to I/V board with 105V on the plates. I have listened for a couple of hours and believe the DAC has more punch and dynamics. Could me my head playing tricks but I am going to keep it this way for now.
Enjoy
Bob
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
