Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 14th March 2010, 08:38 PM   #1091
boudy is offline boudy  United States
Default Y'all are polluting this thread...
The chip GB belongs in its own thread.
Old 14th March 2010, 08:44 PM   #1092
Pocoyo is offline Pocoyo  Indonesia
Pocoyo's Avatar
Default GB Update
AD 1865N-K Group Buy by HOUSING
1. Pocoyo 2 pcs
2. FredLock 1 pcs
3. Housing 1 pcs
4. jasujonas 1 pcs
5. jims 2 pcs
6.
7.
8.
9.
10.
Total GB : 7 pcs in view order (minimum order must 15)
Will buy from DIGIKEY not from CHINA
Old 14th March 2010, 08:55 PM   #1093
Pocoyo's Avatar
Im very sorry
For a new Group Buy of AD 1865 N-K moved here
http://www.diyaudio.com/forums/group...ml#post2118986
thank you
* Dont forget to support your AD 1865 N-K with another *
Old 14th March 2010, 10:24 PM   #1094
torsken is offline torsken  Norway
Originally Posted by gabanyayaya View Post
My mistake...perhaps this is the right way to load the heater to adjust the voltage to 6.3V....3 resistors in series....please correct me if i'm wrong...
Thank you very much for clarifying this. So what is the right way of testing the HV? If anyone can make a similar drawing I will be very thankful.
Old 15th March 2010, 03:41 AM   #1095
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
1. Pocoyo 2 pcs
2. FredLock 1 pcs
3. Housing 1 pcs
4. jasujonas 1 pcs
5. jims 2 pcs
6. mikelm 1 pcs
7.
8.
9.
10.
Old 15th March 2010, 06:13 AM   #1096
housing is offline housing  Hong Kong
O.K. guys. Move your intention to buy AD1865N-K from Digikey here :
http://www.diyaudio.com/forums/group...-1865-n-k.html
Further entry in this thread will be neglected. Sorry!
Thanks to Jeff for setting up the thread for the new international group buy.
Old 15th March 2010, 06:35 AM   #1097
apelizzo is offline apelizzo  Australia
apelizzo's Avatar
After comparing three DACs with some people, they all choose my old DAC with AD1865 with different tube setup.
I think in this project the I/V tube stage can be improved.
The bottom line is: this DAC costed three times the old one, it's far more complicated and it does not reach the performance of my old one.
Good lesson.
Old 15th March 2010, 10:09 AM   #1098
CustomHT is offline CustomHT  Australia
Good lesson.
So where to now??
Are you gonna try and upgrade this dac or I/V tube stage to improve its performance?
Old 15th March 2010, 10:45 AM   #1099
adamus is offline adamus  United Kingdom
do the led bias mod, it makes a very good impact.
cathode bypass caps to my ears sound a little confused and muddy.
Replace the anode resistors with a CSS or gyrator (the later i have not tried). 7.5ma is a little too low on the 5687's, 12ma + is a good idea to be linear.
Old 15th March 2010, 10:54 AM   #1100
tassosk is offline tassosk  Greece
Hi Adamus,
Since I too have DACMagic for reference, how does it compete DACEND2 after the modification in terms of resolution of details?
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright ©1999-2017 diyAudio
