OLD THREAD DAC End by Andrea Ciuffoli OLD THREAD DAC End by Andrea Ciuffoli - Page 105 - diyAudio
Go Back   Home > Forums > > >
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 9th March 2010, 07:40 PM   #1041
agithegreat is offline agithegreat  United Kingdom
Originally Posted by adamus View Post
voltage wise, and heater wise the specs are pretty much the same.
However, the 6n6p has a completely different pinout, so you will need to either.... air wire your sockets, or cut traces and reroute using wire to the socket.
the pinouts couldnt be much more different... frustratingly.
Thanks, I saw that. But how can this say that it's an exact replacement for a E182cc when it's clearly not according to those pin outs?
Old 9th March 2010, 07:49 PM   #1042
adamus is offline adamus  United Kingdom
specswise its very similar, that is it though
Old 9th March 2010, 07:59 PM   #1043
Thanks, i'll keep searching for some 5687's or e182cc's then.
Old 10th March 2010, 02:17 AM   #1044
quanghao is offline quanghao  Viet Nam
OLD THREAD DAC End by Andrea Ciuffoli Send a message via Yahoo to quanghao OLD THREAD DAC End by Andrea Ciuffoli
Some image of my friend s DAC-end2, no I/V stage
Old 10th March 2010, 02:19 AM   #1045
He use Cap Teflon input Digital, I love that, the sound is exelent
Old 10th March 2010, 06:59 AM   #1046
very nice, whatis he going to use for IV, or does he have a pre with a lot of gain?
Old 10th March 2010, 07:20 AM   #1047
apelizzo is offline apelizzo  Australia
apelizzo's Avatar
Very nice, with Teflon caps!
Is there any difference in sound between 8412 8414 receivers?
Also guys can you please recommend a freeware Crossover design software?
Old 10th March 2010, 08:20 AM   #1048
Originally Posted by pop music View Post
Hi quanghao,
thanks for schematics and part list, but, can you write on schematics its revision or date ?
There are a lot of schematics on the web, and there is a little bit confusion find the last
one.
Ivano
yes! I call DAC-END2
Old 10th March 2010, 01:01 PM   #1049
vzs is offline vzs  Europe
Hi Quanghao!
My boards arrived today, very nice indeed.
Thank you,
Zsolt
Old 10th March 2010, 01:42 PM   #1050
Default BOZ or JFet BOZ for line amplification
I might be cursed and thrown out asking this in a thread with so many tube lovers
Did somebody try a Bride Of Zen ( BOZ ) approach for the line level amplification?
or it's JFet counterpart Jfet BOZ (Lineup version with a bit lower THD ~0.06% or Nelson Pass version from 1st page) ?
In simulations both versions have a very nice, monotonically decaying THD spectrum, as tubes do, with THD from 0.06% to 0.2% depending on parts used.
I don't want to start a dispute between tube vs. fets, just from pure curiosity, as it costs almost nothing, only a good output cap.
Thanks.
OLD THREAD DAC End by Andrea CiuffoliHide this!Advertise here!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright ©1999-2017 diyAudio
