OLD THREAD DAC End by Andrea Ciuffoli - Page 98 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 1st March 2010, 02:45 PM   #971
Default Power Supply
Originally Posted by adamus View Post
I sorted my chattering by dropping the 2.2r to 1r, and the 1k to 700r.
Try just dropping less through the resistors, or get rid of them entirely and jumper, just watch the heat on the reg.
Edit - just noticed i misread your post. I'll whip the cover off and measure for you. Give me ten mins.
I am at the point of testing my supplies.
Adamus:
Did you change each of the 2.2R resistors to 1R?
Is the problem that 9V is not enough at the input?
Bob
Old 1st March 2010, 03:00 PM   #972
adamus is offline adamus  United Kingdom
I did indeed. I would test it, and if you are having trouble regulating then jumper them out, or use a smaller value (0.5ohms).
1r 3w is ok (they dissapate 0.75w)
There is a larger than expected drop through the bridge on both my build and apellizo's
IF you dont have a scope then you'll have to look for ac ripple with a dmm, but the relay buzzing or chattering is a good indication you are out of regulation. My reg needs 1.5v to drop to regulation, hence it slightly marginal.
Old 1st March 2010, 03:07 PM   #973
I do have access to a scope. Will follow closely what you guys have done.
I also have a 12V 1.5A transformer.
For Andrea (Audiodesign)
Did you use the 0-12V, 0-15V R Core for the Salas?
Thanks again
Bob
Old 1st March 2010, 04:13 PM   #974
Originally Posted by quanghao View Post
I show some member still need PCb of DAC so ,I will make about 10 set DAC_end 2, If you like you can write please!
thank you.
1. Strosek: full set
2. boudy : full set
I also would like to purchase full set.
Old 1st March 2010, 05:21 PM   #975
toufu is offline toufu  United States
thank you.
2. boudy : full set
3. ksnider1
4. toufu
Old 1st March 2010, 07:48 PM   #976
Ekkeri is offline Ekkeri  Finland
Originally Posted by apelizzo View Post
The heater power supply is not strong enough and I experienced the relay chattering because the regulator has not enough headroom so it passes AC.
What kind of transformer do you have? 9VAC & 3A? What regulators? LM338 have >2V voltage drop, LT1084 & LT1085 have only ~1V? Just wondering if I need to order more resistors.. Still waiting for the parts. Thanks..
Old 1st March 2010, 07:53 PM   #977
i have 1085, which is 1.5v drop.
I would only just meet the lm338 criteria... so the 1085 is safer.
and yes, 9vac 3A.
I would order a couple of extra resistors, but to be honest, if you have a 9vac transformer then jumpering them out is probably wise if its marginal.
Old 1st March 2010, 07:58 PM   #978
Yeah, I have that R-core so only 8.15VAC spec.. I will change those to 1R at least, I won't be using on-board bridge, maybe MUR860s because I already have those..
Old 1st March 2010, 08:02 PM   #979
8.15vac just jumper them straight off. they arent going to do much ripple filtering at that low impedance, so just get rid,
Old 1st March 2010, 08:35 PM   #980
Ok.
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright 1999-2017 diyAudio
