| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#931 |
yep pefect
#932 |
diyAudio Chief Moderator
I am no use anymore then.
#933 |
its odd, if i cut all the 10ohm dac resistors out, then add them back in one by one the voltage from the reg drops and drops, until it bottoms out at 5.15ish
with just one 10ohm in the 10ohm drops 250mv. this is without dac chips so i dont know whats loading. the other oddity is that the reistance between the gnd and 5v digital is only 400 ohms. MEasureing the current between reg and board, its sits pretty much at the max the reg is set for, hence it dropping out of regulation i think. Cant see a short. next thought is a leaky cap or a short somewhere. Last edited by adamus; 27th February 2010 at 10:14 AM. |
#934 |
DAC end succesfully tested. All voltages are spot on 5.0V <10mV difference between all 5V voltages No problem with relay EVERYTHING works really well. Tested sound -> very well balanced and natural. Best sound obtained with Sprague PIO HyperQ 1uF 300V, also Russian PIO OTK is ok (nice detail) but I have to say both are for me better then Obbligato 1uF 630v MKP. I noticed Obbligato somehow sounds with no soul, the detail is grainy. I don't like it, that's just my taste. PIO Sprague sound "exciting", very relaxed and pleasant and reserve "surprises" to the sound that gives very nice sound stage. ************************************************** **************** Last edited by apelizzo; 27th February 2010 at 12:36 PM. |
#935 |
good to hear.
Interesting comments re obbligato. When you say grainy i say resolving. I always find russian pio a bit.... warm and relaxed (as you say). ALl my voltages are spot on at 5v.... i just cant get +5.5v on the digital reg. Could you do me favour and measure the resistance between the digital + and ground on the dac board. it could help help me. bizarre thing is it sounds wonderful, yet something must be wrong. Last edited by adamus; 27th February 2010 at 12:15 PM. |
#936 | |
I adjusted all Salas shunt at 5.3V. All the voltages on DAC chips are 5.0V with <10mV differences due probably to some tolerances on 1K resistors and or TL431. When I ordered the TL431 I was confused because there are some at 4.9V . I bought those 5V for this project. Can you be more specific about your request. Which resistance you want me to measure? |
#937 |
with it off, literally measure the resistance between the 5vdig input and the ground (terminal block).
#938 |
372 Ohms 373 Ohms with two different multimeters
#939 |
me too, exactly.
that rules out a short or leaky cap i think. You know what, i think i will just leave it. The 5v lines look clean on the scope, nothign is gettign hot. If i adjust the salas shunt just below its max then it regulates well. Sounds great. My thoughts on the sound With jan phillips its a warm dac, no doubt about it. Bass has more presence than my cambridge audio dac magic. So much so i had to pull the speakers from the wall a little further. Mids are typically nice for a tube stage Highs and detail are there. Not as crisp as the dacmagic, but AB'ing between them (which you can do with dacmagic, it has a spdif pasthrough, so i have daisy chained them) the dacmagic doesnt sound as natural. This is with the 120uh filter in, so i may remove it and retest. The Dacend is a relaxing listen, no fatigue at all (which i can get with the dacmagic). image is definatley more coherent with the dacend. Speakers dissappear more easily. |
#940 |
Break-in setup, I still have to find out how to install the large Sprague.
The only criticism to this project is for the power supply for the heater is a little too compact. In Australia in summer it will get very hot then reliability becomes an issue. Look the heatsink for DC power to heater on my previous AD1865 DAC (using 6n6P as rectifier, 5670 and 6n6p cathode follower). Last edited by apelizzo; 27th February 2010 at 01:53 PM. |
| OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli | quanghao | Quanghao Audio Design | 394 | 30th January 2013 01:18 AM |
| Cleo: End to End 24bit 192khz USB DAC with tube output | bcherry | DIY HiFi Supply | 7 | 3rd July 2010 11:15 PM |
| The DAC End 2 by Andrea Ciuffoli pcb + most parts... | prooptiki | Swap Meet | 7 | 31st May 2010 02:21 AM |
| Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... | zxcxz | Tubes / Valves | 2 | 10th July 2009 04:14 PM |
| Andrea Ciuffoli Mosfet Amp | DieterD | Solid State | 16 | 24th December 2001 05:56 AM |
