OLD THREAD DAC End by Andrea Ciuffoli - Page 71 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 15th February 2010, 01:05 PM   #701
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
PartsConnexion does .01 for $1 and .1uf for $2. I dont think they have a minimum order of them.
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Out of stock
Old 15th February 2010, 02:48 PM   #702
Originally Posted by mikel_ann View Post
What do you mean ?
1 x 230V alternative 2 x 115V on primary side ?
Thats exactly what i mean, yes.
Will it be 2 x 115v?
Old 15th February 2010, 03:53 PM   #703
No, 1 x 230V only, but 1 x 115V is as an alternative possible.
Michael
Old 15th February 2010, 04:17 PM   #704
Tea-Bag's Avatar
Michael
Might be interested in a all in one version for 115v.
Old 15th February 2010, 04:35 PM   #705
Ekkeri is offline Ekkeri  Finland
Originally Posted by Ekkeri View Post
What type of specs the L1 & L1 120H should have? Current, tolerance, resistance, core, shielding..? Any recommentations what manufacturer / part number to use? Those are in pretty critical place in the signal path..
Output current from AD1865 is 8mA, so that won't be a limiting factor..
How about this:
Digi-Key - M9947-ND (Manufacturer - RL824-121K-RC)
I'm not completely happy with those. Audionote seems to be using their own silver wire chokes..
Ferrite core, if I remember right..
What kind of choke would be the best? Any analog filter designers here?
Old 15th February 2010, 05:47 PM   #706
tassosk is offline tassosk  Greece
I put an order a week ago and 0.1uf was out of stock.
Old 15th February 2010, 06:59 PM   #707
Michael
Aha, ok. No thanks then, i wanted an 'all in one', which i could use currently in USA, but still use it when back home in the UK.
Old 15th February 2010, 09:35 PM   #708
I talked to a guy in Germany cause the transformer. He is building perfect transformers for valve-amps.
The Anode-current is 30-36 mA per valve, s that right ?
We can get a very good transformer for "payable money" which delivers
3 x 12v / 1 x 9V and 1 x 250V.
Hope to can tell you more next week.
regards Michael
I'm interested too. Your previous GB on AD1865 has been executed perfectly.
Old 16th February 2010, 12:43 AM   #709
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by sugden View Post
I check my local Farnell & RS website, they selling Vishay Roederstain MKP1837 0.1uF & 0.01uF very expensive. I will find other source. Can i use Sprague Black Beauty 0.01uF/600V as input cap. at C28 & C29 on DAC-end board? Thanks
Yes! it is a good way! I had to place on the PCB for better use capacitors in the input (C28, C29) or can use the cap better if you have it. the sound is better when you choice the better cap for input! Not need 0.01uf/600V, 100V is Ok
The output capacitor (c26, c26= 0.01uf ) // R 200 Ohm you use only mica is ok
Old 16th February 2010, 04:43 AM   #710
sugden is offline sugden  Singapore
Hi Quanghao, can you advice us what type of inductor or choke should we use as L1 and L2 on the Dac-end board for good sounding? Thanks.
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright 1999-2017 diyAudio
