| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#591 | |
thank
Group buy DAC-END R (ES9018) full assembled board update 21/5/2013 : https://docs.google.com/spreadsheet/...FE&hl=en#gid=0 |
#592 | |
Please give me your opinion regarding all these polyester caps in parallel with Oscon and near the AD1865 and CS8141. I would prefer MKP instead MKS. I've got some axial polystyrene 33nF to mount vertically. I bought some Vishay BC MKS but I don't feel confident to solder them. I excluded any Wima. Also those cheap ceramic capacitor seam to work very well in some positions. What do you recommend? Last edited by apelizzo; 8th February 2010 at 11:43 AM. |
#593 |
mkp woul be good, but i would be suprised if you hear the difference. I used mks and would again.
#594 | |
Can you scan it like Patrick for me? Im in Indonesia.... |
#595 |
My boards arrived today. Good work,
Thanks for your effort. |
#596 |
Quanghao,
Both pcbs of EUVL and mind are received. Thanks a lot for organise the GB. Mark |
#597 |
Thank you!
#598 |
quanghao, my boards arrived today in good condition. They look great. Many thanks again for arranging to have them made & sending to group buy participants.
Re power transformers, in a previous post andrea suggested the following: LS70-1 (2x15V, 1x12V) & R80-55 (1x250V, 2x9V). apelizzo, does the Murata DA101C replace, or is it an alternative for the Newava S22083? |
#599 |
Any digital input transformer could be used in this project so also the Murata DA101C and Newava S22083 probably are good.
#600 |
quick question regarding the inductors (120uf) From farnell i can only find a choke with self resonant frequency of 10khz.
could i jumper the choke, the RC filter remains. |
| OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli | quanghao | Quanghao Audio Design | 394 | 30th January 2013 01:18 AM |
| Cleo: End to End 24bit 192khz USB DAC with tube output | bcherry | DIY HiFi Supply | 7 | 3rd July 2010 11:15 PM |
| The DAC End 2 by Andrea Ciuffoli pcb + most parts... | prooptiki | Swap Meet | 7 | 31st May 2010 02:21 AM |
| Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... | zxcxz | Tubes / Valves | 2 | 10th July 2009 04:14 PM |
| Andrea Ciuffoli Mosfet Amp | DieterD | Solid State | 16 | 24th December 2001 05:56 AM |
