OLD THREAD DAC End by Andrea Ciuffoli - Page 53 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 5th February 2010, 02:47 PM   #521
vzs is offline vzs  Europe
Default Low voltage tubes?
Originally Posted by adamus View Post
yes it can, but it would need a redesign of the PSU (i would forget using the PS pcb, unless you want to keep the filament supply section) and then as you say, changing values.
if you are worried about the voltage.... read read read, then bite the bullet and do a high voltage project.,
The PSU pcb could remain, the 6.3V filament supply is OK, only the high voltage part must be adapted for lower voltage, 12 or 24 V.
A single simpler transformer could be used that would fit all.
And yes, maybe I'm worried a bit of the high voltages and if there is an alternative I would try that.
Is somebody who can help on this?
Thanks!
Old 5th February 2010, 03:08 PM   #522
apelizzo's Avatar
Thanks!
I had similar aversion and fear towards tube amplifiers.. until I've heard the sound, then all fear went away including my solid state amplifier.
There are low voltage tubes, I know a company using for buffering CD players output. But I don't think you should trade good performance for volts. You need to be methodic and careful as there is a level of danger. First until you are confident work with only one end on HV parts the other keep it in your pocket so if it happens the current does not go from one hand to the other through your heart.
I'll find out anyway if you wish to get used to HV little by little. But this project is mostly all on PCB...
Old 5th February 2010, 03:21 PM   #523
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Im Finis DAC-end2! that is ok! Can you see!
Old 5th February 2010, 03:24 PM   #524
and
Old 5th February 2010, 03:33 PM   #525
Originally Posted by tassosk View Post
Can I use 180uF/20V Oscons instead 220uf? BOM says 100-220uf
That is Ok!
you can use 100- 220uf max!
Old 5th February 2010, 03:37 PM   #526
le´flu is offline le´flu  Germany
Hi Quang Hao,
looking great...... very good work.
Where did you get the housing?
Greetings Ulf
Old 5th February 2010, 03:44 PM   #527
I do not understand this :
**Where did you get the housing? ***
Can you show me please???
Thank you!
Old 5th February 2010, 03:48 PM   #528
i meant:
where did you buy the box / cabinet / case or what ever
the right word is ;-)
Greetings Ulf
Old 5th February 2010, 03:52 PM   #529
Originally Posted by le´flu View Post
i meant:
Greetings Ulf
Oh! now I seen! thank! I buy in the shop in China eshopdiclub.biz
Old 5th February 2010, 04:21 PM   #530
adamus is offline adamus  United Kingdom
post 524 the salas reg is lit up on the right, yet from the pic no wire from transformer. Have you routed power from another salas reg under the boards?
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright ©1999-2017 diyAudio
