| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#501 |
#502 |
I am going to order a customer toroid for this. It will work out cheaper than buying several R-cores.
Are these specs right HT 0-230 @ 0.15 amps filament 0-9 @ 3A salas1 0-12 @ 0.5A salas2 0-12 @ 0.5A salas3 0-12 @ 0.5A Thanks Adam. |
#503 |
[QUOTE=adamus;2074424]I am going to order a customer toroid for this. It will work out cheaper than buying several R-cores.
Are these specs right HT 0-230 @ 0.15 ampsanh dang ban la chat nhe filament 0-9 @ 3A salas1 0-12 @ 0.5A salas2 0-12 @ 0.5A salas3 0-12 @ 0.5A THat is Ok But R-cores 3 A is not good! not enough mA, because it is less, I see that!
http://www.audiodesignguide.com |
#504 |
yes. if you went the ebay Rcore route then you'll need three transformers. Shipping would get very expensive.
I had a quote from a british firm for £75 for a custom toroid. I just Pm'ed a guy from the ukraine for a price, i get back to everyone with the result if favorable. |
#506 |
165 looks low to me.
#507 |
Yes, 165V is too low.
In the DAC End ver. 1 are necessary only 200V dc because all the power supply voltage go on tube anode. In the DAC End ver. 2 we must use 265-275V to get a low distortion because many voltage are lost on anode resistors and on the anode there are about 180v. See in previous page my choice for the transformers. Here another good source for OS-CON V.A. Hi Fi www.VocativeAudio.com The advanced Hi-Fi shop in China-Hong Kong |
#508 |
If you are searching a good custom trasformer manufactor I suggest the Italian Bartolucci
Ricerca e Sviluppo - Bartolucci Transformers - Products List - Power Transformers Toroidal The price and the characteristics are very interesting. I have payed more the 2 Chine r-core. |
#509 |
To get the best performance by this DAC project it is necessary use on DAC output module a 200ohm MK132 Caddock resistor.
For all the other resistor on the signal path has been considered good a parallel of two normal 1% metallic oside resistor with inverted phase to compensate some of their inductance. Also the four 2w resistors must be connected with invereted phase (colors). |
#510 |
In my project I will use the following 6 caged PCB potted transformers (easy to find, compact and doesn't look messy):
1) 30VA PCB toroid 240pri 9+9sec parallel connected to 2) 9+9 parallel to get 240VAC for HT. (PRI-SEC-SEC-PRI) 3) 30VA (same as 1) PCB toroid 240pri 9+9sec parallel for DC HEATER 4) 10VA PCB toroid 240pri 9+9sec parallel to SALAS DIGITAL 5) 10VA PCB toroid 240pri 9+9sec parallel to SALAS ANALOG +5 6) 10VA PCB toroid 240pri 9+9sec parallel to SALAS ANALOG -5 Last edited by apelizzo; 5th February 2010 at 10:59 AM. |
| OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli | quanghao | Quanghao Audio Design | 380 | 21st April 2012 07:00 PM |
| Cleo: End to End 24bit 192khz USB DAC with tube output | bcherry | DIY HiFi Supply | 7 | 3rd July 2010 11:15 PM |
| The DAC End 2 by Andrea Ciuffoli pcb + most parts... | prooptiki | Swap Meet | 7 | 31st May 2010 02:21 AM |
| Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... | zxcxz | Tubes / Valves | 2 | 10th July 2009 04:14 PM |
| Andrea Ciuffoli Mosfet Amp | DieterD | Solid State | 16 | 24th December 2001 05:56 AM |
| Page generated in 0.13835 seconds (71.11% PHP - 28.89% MySQL) with 11 queries |
