OLD THREAD DAC End by Andrea Ciuffoli - Page 41 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 29th January 2010, 10:19 AM   #401
le´flu is offline le´flu  Germany
Hi to all,
thinking trough all the projekt and reading all the DacEnd
pages there are still a few questions:
@Quang Hao: To what idss should the sk170 in the salas-reg
be matched for best performance?
@andrea: will there be any changes in performance if one would
use 220R IV-Resistors instead 200R?
Do you suppose a sonically upgrade using the ll1660 transformers
in the dacend?
Would you recommend the lundahl digital input-transformer or
which one?
Greetings Ulf
Old 29th January 2010, 02:10 PM   #402
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Hi!
unnecessary matche 2sk17
It is ok you can you R 220 Ohm,
in the dacend?
Yes, If you like that, so you can you digital input-transformer the sample
Old 29th January 2010, 05:34 PM   #403
savvas is offline savvas  Greece
First things first : a question any boards for full set left ? (been away for awhile)
I haven't read any impression of this implementation vs other AD1865.
For example Adrea did salas regs made some difference in overall performance. I was thinking powering an AD1865 with superegs (or salas) directly, again what are these 431s doing near the chip ?
Old 29th January 2010, 08:06 PM   #404
hotzman is offline hotzman  Romania
Hi Quanghao,
Can I register? I'm interested to buy 2(two)full set DacEnd.
I can already pay through Paypal?
Thank you!
Old 29th January 2010, 08:28 PM   #405
vzs is offline vzs  Europe
Good question, I myself thought why are they needed, so I presume these:
- for the analog part I could not find a good answer. One could try without them to see if there is any difference
- for the digital part the one that feeds the AD1865 might be good to separate from the digital voltage but a small 47uH coil as Andrea did might be enough as well
I think they are used for the sake of completeness but they could be left out if one dislikes them.
Old 29th January 2010, 11:08 PM   #406
YES! the Salas shunt is very very exelent Power supply for DAC or Or any other pre or phono!!!
We use A little post shunt regulators using the TL431 has been inserted to separate all the power supply like suggested in the datasheet of AD1865 and CS8414. And the sound is better!
***I think they are used for the sake of completeness but they could be left out if one dislikes them***
That which is distinct from the other DAC!
You can se in the web: DAC End 2 - the AD1865N-K with single ended vacuum output stage
Old 29th January 2010, 11:11 PM   #407
Originally Posted by hotzman View Post
Hi Quanghao,
Thank you!
Yes! but you can wait me will make more some PCB.
now I only have the numbers you have for me please!
Quanghao
Old 29th January 2010, 11:12 PM   #408
apelizzo's Avatar
Default 431s
I have the same question regarding the use of shunt 431. According to Andrea's DAC Final Test page he states:
"The shunt regulator has been eliminated after the first 30 minutes because the sound was horrible using this and all the +5V has been generated from a single LT1085."
comment: the good LT1085 has a wider frequency response similar to LM317, never use 7805.
I would like to know why now are back again.
Old 30th January 2010, 05:05 AM   #409
Some image ! i m doing make it!
Old 30th January 2010, 10:12 AM   #410
Quanghao
So, we have to wait. Are you gonna take pre orders or wait till the new pcbs arrive ?
If I had my way I'd have these 431s and everything accompanying them taken out of the main board. Maybe an extra board. I know it's kind of fuss, all these extra cables but more freedom is accomplished this way.
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright ©1999-2017 diyAudio
