OLD THREAD DAC End by Andrea Ciuffoli - Page 201 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 9th April 2011, 07:20 AM   #2001
Yomanze is offline Yomanze  United Kingdom
Hi looking at DAC End 2 - the AD1865N-K with single ended vacuum output stage and the measurements in particular. 2.67% THD??? Is this right as the original DAC End measures well under 0.1% in all measurements.
Old 30th April 2011, 07:20 AM   #2002
Hi, can someone advise me if these transformers will work design old end dac salus shunt for DAC. I understand I need 9/12 volt 300ma x3.
10 v center tapped
EDCOR Electronics Corporation. PWRC10V2A-1
Any other suggestions of where to get such power transformers i the USA. For the I/V power supply I found a good 250v and 9 volt from Elcor, but cannot seem to find these 9/12v transformers easily besides those for lights. Would it be necessary to use a better quality audio transformer here?
thanks, John
Old 30th April 2011, 08:57 PM   #2003
BudP is offline BudP  United States
BudP's Avatar
I made a run of power transformers for the Salas shunt regulator and still have three of them. They are six 9 vac @ 200 ma windings and are heavily shielded to cut airborne radiation. A number of folks now have them in use. PM me if you are interested.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 1st June 2011, 09:00 PM   #2004
Ryssen is online now Ryssen  Sweden
Ryssen's Avatar
I asked in another thread and IŽll ask here to.
Quanghaoo you still have the old I/V stage boards for sell?
Or if you have the new I/V board I can use that one.
Or if sommeone else have a spair they dont need.
Old 2nd June 2011, 06:16 AM   #2005
Ryssen's Avatar
Ok,I got a new board from Quanghao.
Old 28th July 2011, 07:34 PM   #2006
Has anyone physically separated the ground trace between the ANA and the DIG on the older Dac Board PCB and reconnected it similar to how the new one is, referencing the connection diagram?
Old 18th September 2011, 03:48 PM   #2007
antos71 is offline antos71  Italy
Hello!
I'm studing the electric diagram of DAC End 2. What is the voltage of anodic if i use the 6DJ8?
Antonio.
P.S. Excuseme for my English!
Old 18th September 2011, 09:43 PM   #2008
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by antos71 View Post
Hello!
Antonio.
for 6DJ8
+ B= 250 V
V anode = 90V
DAC-END The best DAC AD1865- UPDAT 2011
Old 19th September 2011, 02:24 PM   #2009
Originally Posted by quanghao View Post
for 6DJ8
+ B= 250 V
V anode = 90V
Hi Quangao!
Thank you!
Excuseme but i believe that i don't understand.
In this picture of Dac End 2010 + B is 200 volt, isnt' it?
Maybe i have got wrong...please can you help me?
Thank you .
Antonio.
Old 19th September 2011, 11:05 PM   #2010
Hi antos71
is it! you do is great! post # 1681
Thank you
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright ©1999-2017 diyAudio
