OLD THREAD DAC End by Andrea Ciuffoli - Page 200 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 6th November 2010, 04:15 PM   #1991
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by COX77 View Post
It is a long time and j have never received my boards
Philippe
You not get the PCb DAC-end round 2??
Old 6th November 2010, 04:46 PM   #1992
Originally Posted by Dear77 View Post
Hi Guys,
Ive a question- has it ever happened to any of you that one of the dac elements close to AD1865 gathered 50 Hz transformer noise that was audible in the speakers? i know that my transformer is too close to the pcbs but the guy i bought it from assured me its screened. When I put in optional chokes, its even a bigger nightmare- noise is audible at 9 oclock. Its less noisy when I put in a piece of steal between the transformer and pcb where the chokes and wires joining pcbs are. Thx for help
Oh! That is the transformer!
It is very near the chip and tube! Not good!
You can try take it go out the chassis, and test again!
Old 7th November 2010, 03:54 PM   #1993
phrarod is offline phrarod  United States
Originally Posted by Strosek View Post
Quanghao... Here is one...
PLEASE NEW THREAD AND NEW BOM
It's very confusing having differrent projects all in one thread. Threads are free! It makes sense! Let's do it already!
So is this the right one? 1N5819RL STMicroelectronics Schottky (Diodes & Rectifiers)
Old 23rd November 2010, 01:22 AM   #1994
toufu is offline toufu  United States
i built the dac. i have 3 ad1865 chips, one gives one channel, the other 2, no sound. Can i assume the chips are bad?
Old 24th November 2010, 06:09 AM   #1995
Send a message via Yahoo to ThuyTN
Are you sure your DAC is working properly?
Old 1st December 2010, 09:01 PM   #1996
Default dacend almost done
Hi, here is my DAC-END almost done. I'm working on front panels to replace temporary plexiglas.
Old 1st December 2010, 09:17 PM   #1997
adamus is offline adamus  United Kingdom
nice - i see the salas hv shunt is in there too, it performs well indeed.
Old 1st December 2010, 09:25 PM   #1998
indeed, it's must. SSHV is big improvement over original IV power supply. Highly recommended for DAC-END.
Old 2nd December 2010, 01:30 AM   #1999
you use 5687! so the SSHV need low current, R1 ( R set current) = 56R, it is ok!
An measure the voltage drop on R 56R, And V: 56 = mA ( toltal current)
Old 20th March 2011, 05:20 PM   #2000
I've had a problem
The DAC stopped working yesterday. I pulled it apart and the power supply for the DAC (the salas shunt). has gone a cropped on the digi supply.
The 2 resistors have got extremely hot. So hot they melted my poor solder join. So I resoldered them back together and it's working again.
However the resistors are very hot to the touch. Also the 3 dropper LED's are only illuminating occassioanlly. Sometimes they don't come on at all. Other times they come on for maybe 2 minutes, then they go out.
The other parts of the shunt are operating fine (the ana. side).
Any idea's anyone?
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright 1999-2017 diyAudio
