OLD THREAD DAC End by Andrea Ciuffoli - Page 196 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 8th August 2010, 11:20 AM   #1951
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by flocchini View Post
HELP
Problem with Salas HV
Using 0-250 Rcore -260V AC at input
250VDC after rectifier?
Have blown 2 9610s
THe 470 ohm resistors start smoking after 2 seconds. Obviously too much current
No obvious shorts on board.
Where do I start troubleshooting
Bob
You see this image
What about the Led??
May be Mje 350 died , so 840 get all mA
Old 8th August 2010, 01:08 PM   #1952
hotzman is offline hotzman  Romania
I completed the Salas HV! Everything is perfect, I can adjust the output voltage ,but IRF840 is very hot and smoke somewhere !!!!
Forward suggestions!
Thank you!
Old 8th August 2010, 02:58 PM   #1953
Send a message via Yahoo to ThuyTN
Did you use a load when adjusting the voltage? You should have it. The IRF840 accounts for 20% of the true load.
Old 8th August 2010, 04:43 PM   #1954
QuangHao:
Thanks for the reply.
I have the IV and Salas HV board which I am building to power the E182CC IV board.
I will check the MJE 350.
The 3 LEDs light.
R1 (33 ohms) is also very hot so it draws excess current.
Oh. I don't have a 1N3838 installed. Did not see it on the BOM. Will try to find one in my parts.
Best
Bob
Old 9th August 2010, 10:37 AM   #1955
flocchini
No use 1N3838 ! I not like it!
Old 10th August 2010, 12:10 AM   #1956
hfar is offline hfar  Portugal
Originally Posted by quanghao View Post
Hi all!
I plan to make PCB for i / v DAC use:
1. PCB use E182CC tube and output transformer.
In this link circuit:
DAC End - the AD1865N-K with single ended vacuum output stage
2. Using A844 PCB Opam
What you are interested please subscribe to the list:
1..
Hi Quanghao,
Sorry for this question, but I think that you are thinking to provide separated entrys for power supplys, mainly for separated channels. This is correct?
Old 10th August 2010, 12:21 AM   #1957
Per Quanghao I will not use the diode across the 9610.
I found out that my 47 ohm resistors were 470 ohms not 47. They are marked 47. This happened to a fellow DIYer a couple of years ago. I usually check with a meter before installing but became impatient. Live and learn. I have replaced semiconductors and will see how things go later tonight.
Old 10th August 2010, 02:42 AM   #1958
Originally Posted by hfar View Post
Hi Quanghao,
Hi! i use SSHV for All project. In thi case have one tube E182CC, and need 20Ma for tube, so one supply it is good??
Do you have any idea? Can you tell me please??
Old 11th August 2010, 03:41 AM   #1959
Everything is working with the Salas HV part of the IV - Salas HV board. It is providing 270V to the e182CC IV board.
Thanks to all
Best
Bob
Old 11th August 2010, 03:45 AM   #1960
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Where did you put a 470R instead of a 47R? On the base of the MJE?
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright 1999-2017 diyAudio
