OLD THREAD DAC End by Andrea Ciuffoli - Page 194 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 3rd August 2010, 04:47 AM   #1931
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
Originally Posted by Jeffrey Davison View Post
If I can use 6H30DR's and Sowter 9762's I'm in.
JD
6h30 DR , i love it!
You can use Sowter 9762, R gird, You can use or no, see that!
Sowter Transformer 9762 DAC INTERFACE* FOR AD1865N-J
Old 3rd August 2010, 09:52 AM   #1932
what is the vantage to put a transformer between DAC and I/V?
With my little knowledge I think it would be better put a transformer after the tube to illiminate the C2, how Andrea have made in his DAC-End.
Klaus
Old 3rd August 2010, 07:35 PM   #1933
hotzman is offline hotzman  Romania
Hello guys.
What is the equivallent for 1N4142?
Thank you!
Old 4th August 2010, 01:35 AM   #1934
Originally Posted by hotzman View Post
Hello guys.
Thank you!
you can all you Zenner diode 6-12V, It is protect IRF 9610, 840
Old 4th August 2010, 01:38 AM   #1935
Klaus
yes! transformer out put is the best for DAC-End!
Old 4th August 2010, 02:56 AM   #1936
[QUOTE=quanghao;2261185]Hi all!
I plan to make PCB for i / v DAC use:
1. PCB use E182CC tube and output transformer.
In this link circuit:
DAC End - the AD1865N-K with single ended vacuum output stage
2. Using A844 PCB Opam
What you are interested please subscribe to the list:
1..flocchini transformer
Old 5th August 2010, 05:12 PM   #1937
Hi Quang Hao,
with the new PCB for SSHV for I/V Pre you have changed the circuit, you are using now the same of the the D3a phono pre.
Im also interested in the E182CC version with output transformer, why you dont make a two PCB version, SSHV and I/V seperated.
I just have 2 of the D3a SSHV PCB.
You have chematics for the new I/V-SSHV for DAC?
Klaus
Old 6th August 2010, 01:34 AM   #1938
Hi klaju1955
Do not separate between SSHV and I / and E182CC wit transformer output, I will send you the following diagram.
You're signing on to the list! Thanks for the interest.
Old 6th August 2010, 01:41 AM   #1939
My friend have finis Dac-end 2 updat, he use tube 6dj8 out!
Old 6th August 2010, 04:26 AM   #1940
Hey guys, about to order 1uf caps. I'm going to order 2 x 1uf Mundorf Mcap Supreme for the I/V. Was just wondering if I need premium caps for the Salas Shunt as well.
Also, in the BOM, it says 2A/800V Diode 1N5819. Is it suppose to be 1N5062's instead cause the 1N5819 is 1A/40V.
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright 1999-2017 diyAudio
