OLD THREAD DAC End by Andrea Ciuffoli - Page 191 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 28th July 2010, 07:20 AM   #1901
BudP is offline BudP  United States
BudP's Avatar
Here are the four choices. All within the same core size range.
Fig 1 is a bare coil, 9.3 kg flux load with copper strap wrapped around coil and adjacent core.
Fig 2 is the same mounted within one piece end bells
Fig 3 is full shielding and 9.7 kg flux load. Channel frame mounting.
Fig 4 is a bare coil, 9.3 kg flux load with copper strap wrapped around coil and adjacent core. Channel frame mounting.
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 28th July 2010, 07:24 AM   #1902
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
one 9.3 kg???
it is very heavy!
Old 28th July 2010, 08:30 AM   #1903
BudP's Avatar
Sorry, 9.3 kilogauss... not kilograms.
Old 28th July 2010, 06:27 PM   #1904
phrarod is offline phrarod  United States
On another note - OSCON SP 47uF/16v caps.
Through my company I was able to buy a bag of them. I'll have around 50 to sell as its too many for me to use. This is directly from a distributor so no worries about being knock offs.
Its probably a best deal for NA/SA since Farnell as explained earlier sells them is small quantities in England.
Farnell sells them for $3.90 ea plus s/h
I will sell them for $2.00/ea plus shipping. PM me if you are interested.
Again these are the Audio Grade SP versions. Other versions such as SA, etc are not the audio grade.
Old 28th July 2010, 06:42 PM   #1905
you have a foto of the caps, I´ve bought on Ebay and the seller says they are SP, but I didn´t see nothing declared on the cap like SP, only a G?
Klaus
Old 28th July 2010, 08:15 PM   #1906
The lettering should be gold. I don't have them yet. When I get them I'll photograph them. For now look at partsconnexion... Capacitors_Electrolytic_Sanyo_Oscon
I also bought some a while back after being told they were SP, but they're not. They have a G and the lettering is gray. All SP have gold lettering to my knowledge. SP is the only one specifically for Audio in the organic series.
Old 28th July 2010, 09:26 PM   #1907
Mine a like the gray ones you´ve bought, now I saw another offering them like SA. There are a lot of sh... goods and sellers on Ebay.
Reserve 10 for me, please.
Klaus
Old 28th July 2010, 09:31 PM   #1908
Klaus. Will do but PM me so I can keep a list. I know what you mean about eBay. I have a drawer of bogus parts I bought and they know its too much of a hassle to return. That's why I wanted to offer the real deal to people here.
Old 29th July 2010, 02:24 AM   #1909
Hi phrarod!
you can make groub by Os-con 47uF Sp in this topic???
Many member like it!
Thank
http://www.quanghao.com
Old 29th July 2010, 03:56 AM   #1910
Strosek is offline Strosek  Canada
Count me in for 10 and as you said I'll also send you a PM.
Thanks!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright ©1999-2017 diyAudio
