| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#1521 |
To use the DAC-END with tube, I connected the jumper on 1 and 2. Is it correct ? The tubes should invert. So the signal goes from pin 26 of the CS8414 to pin 10 of the AD1865.
In this case what is the 74HC04 doing ? Thanks, Davide |
#1522 |
[QUOTE=Nikon1975;2169620]To use the DAC-END with tube, I connected the jumper on 1 and 2. Is it correct ?
no correct! What is the sound ???
Group buy DAC-END R (ES9018) full assembled board update 8/5/2013 : https://docs.google.com/spreadsheet/...2c&hl=en#gid=0 |
#1523 |
So I have to connect 2 and 3 ?
D. |
#1524 | |
Hi, Good work! Please post some pictures ![]() Regarding 5.3V.. What is your resistor value for R13 on salas shunt? Also measure gate - source on the last mosfet. It should read around 4V. If not you need to lower the R13 resistor value. Best Regards David
http://www.blogotheque.net/-Concerts-a-emporter- Last edited by Yunick; 29th April 2010 at 12:04 PM. |
#1525 | |
I see you have Wima on the output of I/V. how do you like them? I tried RIFA PHE426 1µf and liked it very much. You have some good time ahead trying different mods ![]() Best Regards David
http://www.blogotheque.net/-Concerts-a-emporter- |
#1526 |
#1527 |
This is a picture of the working prototype.
I used one transformer with two secondaries for +-5V one for +5V. The black small one is a 5H choke and the black big one is the power transformer for HV. this is temporary. Still did not understand the right position for the jumper, and how many regulators and filament supply I should use. BR, Davide |
#1528 | |
Thanks for the picture ![]() If you want the signal to be in phase you need to connect a jumper between 2 and 3. If not. Use 1 and 2. Your prototype seems to be complete to me. Nice work with the shunt reg for the tube stage! Best Regards David
#1529 |
You mean the phase out of the DAC-END circuit or out of the Tube stage ?
The tube stage itself inverts. D. |
#1530 |
So I have R13=10 ohm
VgsQ16=3.3 V R7=33 ohm VgsQ10=3.6 V R1=33 ohm Vgs=3.8 V I have available resistors of 27 ohm, 22 ohm , 8.2 ohm and 6.8 ohm. Do you think I should replace them ? Are the heatsink really needed ? It's not that hot. D. |
| OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli | quanghao | Quanghao Audio Design | 394 | 30th January 2013 01:18 AM |
| Cleo: End to End 24bit 192khz USB DAC with tube output | bcherry | DIY HiFi Supply | 7 | 3rd July 2010 11:15 PM |
| The DAC End 2 by Andrea Ciuffoli pcb + most parts... | prooptiki | Swap Meet | 7 | 31st May 2010 02:21 AM |
| Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... | zxcxz | Tubes / Valves | 2 | 10th July 2009 04:14 PM |
| Andrea Ciuffoli Mosfet Amp | DieterD | Solid State | 16 | 24th December 2001 05:56 AM |
