| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#1411 |
Yes, I agree the sound is very addictive and very refreshing. I really enjoy 6pm to 1am every day, never tired to listen and I switch off with regret. One of the mods I'm waiting is also the I/V stage power supply upgrade to Shunt Regulator, constant current heater supply and Adamus mod(but with TL431 instead of LEDs). Bye Bye caps.
#1412 | |
#1413 |
How big power handling capacity R5 10k in I/V PS should have? I have 1/4W resistor, but it's so small..
#1414 | |
Can you show us how to do "ADAMUS MOD" is it on Salas Board? It would be very nice if u post with pic ( like lampizator did, with some arrows points some component you've modded) |
#1415 |
See post 986 by Adamus.
Enjoy |
#1416 | |
I have the same transformer as yours, R80-36. I haven't connected yet since I'm still waiting for parts that I ordered. This is how I will connect it You have 2 center tap 3.15V/3A per winding, Gray, Black Gray You have 1 center tap 2.5V/3A per winding, Blue, Brown, Blue To make it 8.15V for the heater filament, you only need the 2 Blue wires, ignore the Brown wire just insulate the end of it. That gives you 5Vac/3A. Then connect one of the blue wires, to whichever 3.15V center tap you want to use, to Gray wire and the black wire will be 0V reference. Measure it with the voltmeter and if you don't get 8.15V, you might want to reverse the connection of black and Gray, as what housing had mention earlier. It might be out of phase. You were also asking if you can parallel the 3.15V winding. I think you can but this will become 6A which I don't recommend. In regards to the 260Vac, I think you can parallel the winding to achieve the maximum current rating, tie up Green and Green wire and orange will be your 0V reference. Let's consult with the veterans here. Guys, correct me if I'm wrong. I'm just trying to help CustomHT. I know he asked this question like 3 times already and nobody had given him a detailed answer of the transformer connection. Thanks, Fred |
#1417 | ||
Use 2 diodes as a full wave rectifier at each green wire instead of a bridge rectifier to get the rectified high DC voltage, orange will be your 0V reference. Last edited by housing; 9th April 2010 at 05:56 AM. |
#1418 |
Do some of you have experience with the e-bay seller for the AD1865 recommended in the board instructions?
Did someone compare how that chips work compared to the Digikey one? Thanks, Davide |
#1419 |
I want to share my work in progress, look at those sausages in I/V stage, lol
#1420 |
Nice work Ksnider1!
Very neat and tidy.
http://www.blogotheque.net/-Concerts-a-emporter- |
| OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli | quanghao | Quanghao Audio Design | 394 | 30th January 2013 01:18 AM |
| Cleo: End to End 24bit 192khz USB DAC with tube output | bcherry | DIY HiFi Supply | 7 | 3rd July 2010 11:15 PM |
| The DAC End 2 by Andrea Ciuffoli pcb + most parts... | prooptiki | Swap Meet | 7 | 31st May 2010 02:21 AM |
| Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... | zxcxz | Tubes / Valves | 2 | 10th July 2009 04:14 PM |
| Andrea Ciuffoli Mosfet Amp | DieterD | Solid State | 16 | 24th December 2001 05:56 AM |
