OLD THREAD DAC End by Andrea Ciuffoli - Page 14 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 3rd January 2010, 08:24 AM   #131
Banned
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
Patrick,
which are the questions ?
Old 3rd January 2010, 08:31 AM   #132
EUVL is offline EUVL  Europe
Whether you need 2x AD1865 for balanced output and what the circuit would then look like ....
I thought this is best answered by someone who has actually developed the original circuit.
Happy New Year and thanks for sharing with us, Andrea,
Patrick
Old 3rd January 2010, 09:00 AM   #133
Banned
Yes, it is possibile get a balanced output using 2 x AD1865 but I don't think this will give a best sonic performances.
A balanced output mean the necessity to add a differential output stage so it will increase the complexity and the cost.
A balanced stage can eliminate some distortion and power supply noise but here we have, in any case, a very low distortion stages and a good power supply.
Old 3rd January 2010, 09:55 AM   #134
Banned
Here the final output stage
THD measurement with and without 10Kohm load.
Output impedance less than 1Kohm
Power supply voltage about 270V
Ik = 2 x 8mA
Freq = 10Hz at -0.7db
Vout = 2Vrms with an input of 154mVrms
THD = 0.3% thd max on 10Kohm load
Old 3rd January 2010, 09:59 AM   #135
Banned
Here others attach
To prevent dc voltage on output durung switch-on and switch off phase a relay will short the output to the ground for some seconds.
The delay circuit is the same used in the my design of Monrio Top-Loader CD Player (value 10000$).
Old 3rd January 2010, 10:16 AM   #136
Someone else was happy with a direct transformer (Sowter 9545) output on the AD1865.
That way you can get balanced output for nothing extra.
AK4396: best solution for output stage
Any comments, Andrea ?
Patrick
Old 3rd January 2010, 11:49 AM   #137
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I have Sowters in my CDP done by Modwright, back when I was more afraid of digital mods. I dont have the schematic, but the unit sounds wonderful. The IRON anyway, cannot be that bad. It does not use any tubes.
Salas Boards GB 2017#1 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards Out of stock
Old 3rd January 2010, 03:12 PM   #138
Banned
Patrick see the my answer in the other forum
Old 3rd January 2010, 03:23 PM   #139
I did.
Patrick
Old 4th January 2010, 03:18 PM   #140
robertor's Avatar
Send a message via Skype™ to robertor
hi quanghao, befor order the full set PCB i'd like to know something about the DAC.
i hope you would forgive my bad english and mine deep ignorance.
then: which type of transformer i need to complete the power supply and the rest of the DAC?
where i can find the AD1865?
ebay?
there are a lot of fake on ebay(opamp, capacitors, etc etc)!
thanks and sorry everybody for my stupid question.
rob
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright 1999-2017 diyAudio
