Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 24th March 2010, 01:35 PM   #1211
vzs is online now vzs  Europe
Originally Posted by apelizzo View Post
First I'm gonna cross the two DACs. New DAC with old tube stage, and old DAC with new tube stage. This way I can identify where is the major issue.
@apelizzo
Did you try the changing you said between your new and old DAC?
Curious about the results...
Old 24th March 2010, 02:03 PM   #1212
Originally Posted by audiodesign View Post
Zsolt,
I am agree with you about the possibility to eliminate the capacitors if we are using a digital input transformers also if the datasheet is not very clear.
About the ground, yes we can keep the input ground separated in the next dac board to use balanced digital input
The data-sheet is indeed not very clear. In order not to confuse others I would say that with this version, so using capacitors at input, the use of transformer is optional. As it offers galvanic separation it is good to use it.
Old 24th March 2010, 03:32 PM   #1213
Send a message via Yahoo to quanghao
Now I have PCB
18 PCB Salas shunt for DAC
18 PCB DAC-end
18 PCB IV- stage for DAC
no have supply for IV ( you can use Salas shunt HV )
if you need it you can write please:
1. Strosek: full set
2. boudy : full set
3. ksnider1: full set
4. toufu : (IV + Supply For IV) x 2
5. ferrari: (IV + Supply For IV) x 3
6. analogdiy: full set
7. wobii: full set
8. Cobra2: (IV + Supply For IV) x 2
9. mikelm: full set
10. le´flu: just one salas reg
Group buy DAC-END R (ES9018) full assembled board
update 21/5/2013 : https://docs.google.com/spreadsheet/...FE&hl=en#gid=0
Old 24th March 2010, 06:47 PM   #1214
Quanghao,
I received an extra set of boards from you. How do I get these back to you minus the shunt reg board? Much thanks.
shambala
Old 24th March 2010, 07:15 PM   #1215
Ferrari is offline Ferrari  Netherlands
2. boudy : full set
5. ferrari: (1x DAC-end) + (2x Salas shunt for DAC) + (3x IV)
7. wobii: full set
9. mikelm: full set
Old 24th March 2010, 07:30 PM   #1216
boudy is offline boudy  United States
Default Update of my entry
2. boudy : DAC-end x 1, Salas shunt for DAC x 1, IV- stage for DAC x 1, Salas shunt HV x 2
7. wobii: full set
9. mikelm: full set
Old 24th March 2010, 07:33 PM   #1217
2. boudy : full set
7. wobii: full set
9. mikelm: full set
11. Joshua_G: full set (1PCB DAC-end, 1 PCB IV- stage for DAC, 1 PCB Salas shunt for DAC).
As I understand, the prices are:
PCB- DAC END = $15
PCB- I/V stage = $15
PCB- Supply for I/V = $15
Shipping = $6
(so far $45)
Plus Payment by PayPal fee %3.5 = $46.575 .
Is that correct?
Shall it be $46.57 or $ 46.58?
(I had to browse back 112 pages to get to the prices)!
Payment made to: quanghao168@yahoo.com.vn .
Old 24th March 2010, 08:42 PM   #1218
Originally Posted by quanghao View Post
Now I have PCB
18 PCB DAC-end
2. boudy : full set
7. wobii: full set
9. mikelm: full set
Hi quanghao, I send you $60 via paypal for full set. I'm confused now. Do I get full set from you ? Is Salas shunt HV better for IV- stage. Please please clarify.
Thansk
Old 24th March 2010, 10:51 PM   #1219
ims is offline ims  Indonesia
ims's Avatar
I want to update with my request:
2. boudy : full set
7. wobii: full set
9. mikelm: full set
12. ims: 2 x PCB-Supply for I/V salas reg
As I understand, the prices will be:
2 x PCB- Supply for I/V = 2 x $15
Shipping = $6
(so far $36)
Plus Payment by PayPal fee 3.5% = $37.26
Is that correct?
I will make a payment to: quanghao168@yahoo.com.vn
Is this your valid paypal account for now?
Thanks.
Old 24th March 2010, 11:03 PM   #1220
Ok i have another problem, on my I/V board.
I had C6 and C2 blow as I put them in the incorrect way around. Since replacing them I no longer get any voltage drop across R1-4 and R13-16.
What have i blown?
I should also say that i do not have the tube plugged in. However when i had voltage drop earlier, i didn't have them in them either. Was it because the cap was the incorrect way around that it allowed current flow and as such gave me a voltage drop???
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 394 30th January 2013 01:18 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright ©1999-2013 diyAudio
