OLD THREAD DAC End by Andrea Ciuffoli - Page 112 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 15th March 2010, 05:05 PM   #1111
torsken is offline torsken  Norway
What about the digital bypass mod done by mister lampizator?
ad1865
"The digital input RCA is installed with a complete bypass of digital input transformer as well as the input buffer chip. I went directly by silver wire - from RCA hot to CS pin 9 (Rxp) , and from cold RCA to CS8414 pin 10 (Rxn)"
"The digital bypass. It is so audible - I can tell you - it is a real thick blanket being removed."
Old 15th March 2010, 06:18 PM   #1112
ad1865
I think there are some great experiments to be performed.
I am away from my house and projects for about 3 weeks.
My plan is to remove the fiter from DAC board and put it on a separate perf board so that I can easily try other IV set-ups.
These will include Oliver's board
Tube-I-zator Professional PCB
This is the Lampizator's set-up in which I will try the 6N2p
I will also try raindrop hui's (AD1865 ref above) tube output (miniature Raytheons)
I also have Welborne's Borbely hybrid which is set-up as a differential output. Depending what I hear with the original board and the two others I may mod it for the AD1865. It uses the 6G8M at 24V. I have also used the 6H6P at 24V in the same board but set up as line stage. Quite interesting.
I will be about 3 weeks behind all of you but will report when I am back to my home.
Thanks to all for their comments.
Best
Bob
Old 15th March 2010, 11:32 PM   #1113
I desperately need a CS8414 on DIP. I bought one from ebay, being told it was soldered, which it wasn't to the converter board.
I attempted to solder it myself, but wrecked the tracks as i have no patience.
Can anyone recommend me a place, or even solder another up for me?
Old 15th March 2010, 11:36 PM   #1114
apelizzo's Avatar
Yes it's hard to solder. I've got this one from ebay and asked to solder and test for me. They done it, mounted and works.
CS8414 CS8414CS to DIP28 (PCB adapter- SOIC28) - eBay Other, Electronic Components, Electrical Test Equipment, Business Industrial. (end time 13-Apr-10 03:54:58 AEST)
Ask to solder and test it for you.
Old 15th March 2010, 11:49 PM   #1115
Thanks, it was those guys who said they'd solder it for me....
Never mind. Will the CS8412 work inplace?
I've contacted them, asking again for a soldered and tested one...
Old 16th March 2010, 12:58 AM   #1116
apelizzo's Avatar
I believe it works but the CS8414 is an improvement of the 8412. Quanghao's friend has one mounted on his pcb
Old 16th March 2010, 01:25 AM   #1117
I'll look for another 8414 then.
Thanks.
Old 16th March 2010, 02:20 AM   #1118
I proberly should have asked them to solder mine for me aswell being my first diy project and all, I just did it myself tho, seemed to turn out alright, guess wont know till dac is finished and its time to test it..
Old 16th March 2010, 03:18 AM   #1119
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
No! dont use 8412
Old 16th March 2010, 03:23 AM   #1120
Exactly the same setup. It's the DAC End with transformer but instead of expensive transformers I've done a tube stage.
So you like DAC-end or DAC-END2???
And what do your friend say???
What tube do you like for IV of DAC-ENd2 ??
thank you!
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 15th October 2016 11:42 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 3rd July 2010 11:15 PM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 02:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 04:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 05:56 AM
Copyright 1999-2017 diyAudio
