| Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests! |
#1101 |
*with LED bias* its more natural than the dacmagic, the depth of the soundstage is greater and it makes the dacmagic sound a bit false (mids / highs too forward).
The dacmagic is brighter, so detail is more in your face, but its all there with the dacend, and i prefer the natural quality. For me, without the led bias i found the bass to loose. IT was too warm and cuddly and a little confused in complex bass passages. I have had a play with a css, and am unsure so far as to whether i like it or not. It tightens the bass further, but you do loose some of that lovely valve sound (for the scientists you probably read that as 'valve distortion'). Its more clinical and detailed, but not sure if i like it or not yet. The CSS also needs a lot of heatsinking, its dropping a lot of volts! |
#1102 | |
Appart the output stage mods, we also have to consider the Salas suggestion regarding the bypass of the 431, if anyone has the knowledge to apply it correctly. |
#1103 |
not sure, its probably not something i will be trying. on the scope there is more noise after the tl431's, so i can see why salas is suggesting it
#1104 | |
Adamus, if you can help me with your experience: my friends told me that the new DAC comparing to other two already has less bass. If I apply your mod am I going to loose more bass? Tell me if you need to know all the parts in the circuit. Sometime oscon are responsible of bass. Do you use the passive filter before I/V? Last edited by apelizzo; 15th March 2010 at 01:31 PM. |
#1105 | |
Good point Adamus, I feel the distortion is also a little high. |
#1106 | |
you wont loose bass, it will be more controlled and the low mids will be better resolved, i found it 'wooly' messy if you like pre mod. Everything is was slightly better resolved for me. i find a lto of people describe wooly bass + low mid as warmth, so you will loose a little 'warmth'. |
#1107 |
Tube stage with 5670 or russian 6N23P designed and used in my old DAC considered having better sound. Gain to be adjusted.
Also added shunt tube regulator on +/-85V Last edited by apelizzo; 15th March 2010 at 02:03 PM. |
#1108 |
My old DAC? what chip do you use???
Group buy DAC-END R (ES9018) full assembled board update 21/5/2013 : https://docs.google.com/spreadsheet/...FE&hl=en#gid=0 |
#1109 |
Exactly the same setup. It's the DAC End with transformer but instead of expensive transformers I've done a tube stage.
#1110 |
Tamura ???
| OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli | quanghao | Quanghao Audio Design | 394 | 30th January 2013 01:18 AM |
| Cleo: End to End 24bit 192khz USB DAC with tube output | bcherry | DIY HiFi Supply | 7 | 3rd July 2010 11:15 PM |
| The DAC End 2 by Andrea Ciuffoli pcb + most parts... | prooptiki | Swap Meet | 7 | 31st May 2010 02:21 AM |
| Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... | zxcxz | Tubes / Valves | 2 | 10th July 2009 04:14 PM |
| Andrea Ciuffoli Mosfet Amp | DieterD | Solid State | 16 | 24th December 2001 05:56 AM |
