OLD THREAD DAC End by Andrea Ciuffoli - Page 106 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 10th March 2010, 02:58 PM   #1051
Ferrari is offline Ferrari  Netherlands
1. Strosek: full set
2. boudy : full set
3. ksnider1: full set
4. toufu : (IV + Supply For IV) x 2
5. ferrari: (IV + Supply For IV) x 3
6. analogdiy: full set
7. wobii: full set
8. Cobra2: (IV + Supply For IV) x 2
9. mikelm: full set
10. le´flu: just one salas reg please
Quantity updated (one additional for a friend).
Old 10th March 2010, 08:13 PM   #1052
Default Important Message To Our Sponsor
Hi Quanghao,
I sent you an message yesterday thatś somewhat important. Can you get back to me.
dshambala
Old 11th March 2010, 04:17 AM   #1053
apelizzo's Avatar
Originally Posted by vzs View Post
I might be cursed and thrown out asking this in a thread with so many tube lovers
Did somebody try a Bride Of Zen ( BOZ ) approach for the line level amplification?
or it's JFet counterpart Jfet BOZ (Lineup version with a bit lower THD ~0.06% or Nelson Pass version from 1st page) ?
In simulations both versions have a very nice, monotonically decaying THD spectrum, as tubes do, with THD from 0.06% to 0.2% depending on parts used.
I don't want to start a dispute between tube vs. fets, just from pure curiosity, as it costs almost nothing, only a good output cap.
Thanks.
Ohh this is OUTRAGEOS!!! *** Just Kidding **
No, I never tried and I don't see why not trying.
I was actually going to design an hybrid tube input mosfet single ended output power amp as an experiment to see if the mosfet stumbles compared to tube power stage. I suspect mosfet is slow compared to tube.
Old 11th March 2010, 05:59 AM   #1054
I have used the following Borbely/Welborne hybrid as a line stage and will use it with a differential output DAC I am experimenting with. As a side comment I have also used 6H6P in the line stage. Sounds good to my ear.
DAC Tube Output Stage Kit
See also the CATO at the same site.
Best
Old 11th March 2010, 06:20 AM   #1055
Well the boards are nearly complete.. Just waiting for the last couple of parts, now its time to order the Transformers..
Which types/models is everyone using? I'm open to suggestions as new to this..
I had a look at the R-core R80-36 on ebay for the IV stage, just that the specs don't sound right.
R80-36 260-230-0-230-260(90mA). 2.5-0-2.5(3A).(3.15-0-3.15)X2(3A)
Is this the right one?
What about to run the salas shunts?
Old 11th March 2010, 07:16 AM   #1056
apelizzo's Avatar
That's the one I've used. Available also from Diyclub.biz
For Salas I've used two separate 10va 9+9V PCB toroidal transformers: one for Digital section (9V) and another for the two 9V 9V for Analog section. Total 3 transformers
Old 11th March 2010, 07:23 AM   #1057
Send a message via Yahoo to quanghao Send a message via Skype™ to quanghao
the Salas shunt need:
2 or 3 : 9-12 V/ min 100mA
You can choice R-core (R26-28) for Salas shunt, It is good
The supply I/V need: 0- 260V min 50mA
The Filament need: 0-9 V min 3A
Old 11th March 2010, 05:34 PM   #1058
Hi Quanghao,
I'm started to find a components on web,I check the part list and I found a mistake.
Part list DACEND2 about capacitors 0,01uF are N.4, but on schematics I found 11 components 0,01uF(10nF): I suppose that only C26-C27-C28-C29 are 0,01uF and all othres are 0,1uF (100nF).
That's right?
Ivano
Old 11th March 2010, 06:49 PM   #1059
What about this transformer, is it ok?
R-Core Power Transformer Tube preamp amplifier 6DJ8 bei eBay.de: Transformers (endet 21.03.10 08:21:16 MEZ)
Primary 117V 50/60Hz , 117V 50/60HZ
Secondary 265V - 0 - 265V ( 50mA ), 6.3V(3A) , 12.6V (1A)
Old 11th March 2010, 07:12 PM   #1060
Salas shunt powered up and working.
Still waiting for farnell for my remaining parts for my I/V.
First ever DIY electronic project from scratch, nearly done.
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright ©1999-2017 diyAudio
