OLD THREAD DAC End by Andrea Ciuffoli - Page 100 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Quanghao Audio Design
Quanghao Audio Design Quanghao Audio Design is a producer of DIY Audiophile Kits and PCB boards, selected from many listening tests!
Old 2nd March 2010, 10:27 PM   #991
wobii is offline wobii  United States
1. Strosek: full set
2. boudy : full set
3. ksnider1: full set
4. toufu : (IV + Supply For IV) x 2
5. ferrari: (IV + Supply For IV) x 2
6. analogdiy: full set
7. wobii: full set
Old 2nd March 2010, 11:06 PM   #992
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
2. boudy : full set
7. wobii: full set
8. Cobra2: (IV + Supply For IV) x 2
Don't believe everything you think...
Old 3rd March 2010, 06:00 PM   #993
I'm struggling to find suitable heat sinks for the salas board.
Can anyone recommend me any?
Thats all i need now and then i'm done too.
Old 3rd March 2010, 06:17 PM   #994
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
2. boudy : full set
7. wobii: full set
9. mikelm: full set
Old 3rd March 2010, 06:21 PM   #995
adamus is offline adamus  United Kingdom
you will be ok without for testing. They dont seem to get that hot if you stick to 27ohms.
i used these, just because i had them..
Rapid Electronics - Electronic Components
The pins didnt fit perfectly so i just drilled the holes slightly bigger.
i am very happy with the dacs performance now. with the led mod its very very pleasing to my ears.
I am bulding a couple of drop in CSS modules too ( cascode depletion mosfets) to test. will report back
Old 3rd March 2010, 07:08 PM   #996
Thanks adamus.
I might just get clip on sinks, yeh they aren't great, but the case will be forcefully ventilated anyway (12v fans operating at ~7v, push pull).
Old 3rd March 2010, 07:11 PM   #997
not sure forced cooling is a good idea to be honest. 5687's tend to be relatively microphonic as a family. both apellizo and i have experience microphonic valves in this dac-end.
you may get a quiet 'ringing'.
Old 3rd March 2010, 07:13 PM   #998
Ekkeri is offline Ekkeri  Finland
I got these today:
TO-220 Heatsink, Small Power Aluminum Heat-Sink, x 4pcs - eBay (item 260481603013 end time Mar-22-10 23:26:12 PDT)
Center hole isn't large enough for M3, but otherwise I think they are a good fit. No need to drill the PCB.
EDIT: Damn.. there is a M3 thread, not a hole..
Old 3rd March 2010, 07:22 PM   #999
Originally Posted by Ekkeri View Post
I got these today:
Thats great. I'll get some. The TO-247 package fits ok?
Adamus, if i get these and they fit i'll stick to passive, thanks for the heads up.
Old 3rd March 2010, 07:46 PM   #1000
Yep.. Maybe 1mm gap between the pcb and heatsink, but not a problem.
OLD THREAD Hi-end phono preamplifier by Andrea Ciuffoli quanghao Quanghao Audio Design 417 16th October 2016 12:42 AM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
The DAC End 2 by Andrea Ciuffoli pcb + most parts... prooptiki Swap Meet 7 31st May 2010 03:21 AM
Custom designed transformer for Andrea Ciuffoli 6c33c OTL AMP.... zxcxz Tubes / Valves 2 10th July 2009 05:14 PM
Andrea Ciuffoli Mosfet Amp DieterD Solid State 16 24th December 2001 06:56 AM
Copyright 1999-2017 diyAudio
